Old 06-14-2022, 07:43 PM
Zooguy Zooguy is offline
Default Dashboard clips
So I got my dash pad removed so that way I could put a new speaker underneath but whenever I got the passenger side out the clip that goes in the dashboard area came out and I've looked for three weeks and cannot find it anywhere in the car does anybody know where I can locate these?
Old 06-15-2022, 01:07 AM
webfoot's Avatar
webfoot webfoot is offline
Looks similar to what is used on other full wrap around dash pad & metal dashes, look up ones used for a 68 gto to compare.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 06-15-2022, 11:38 AM
pfilean's Avatar
pfilean pfilean is offline
Restoration Specialties?
The Following User Says Thank You to pfilean For This Useful Post:
Old 06-15-2022, 02:11 PM
dataway's Avatar
dataway dataway is offline
Look the same as 68 AC dash pad clips ... I've never seen them reproduced, all I could find were the square dash pad clips which I think were used in the non-AC 68 dash pads.
Old 06-15-2022, 02:21 PM
Mr Twister's Avatar
Is that a cage nut? if so they are readily available from places like fastenall.
Old 06-15-2022, 02:32 PM
dataway's Avatar
It's a clip that holds a push-in pin with a knob on the end.
Old 06-15-2022, 08:30 PM
mgarblik mgarblik is offline
They are a strange spring steel clip. As far as I know, they are 66 full size car only. They are definitely different than a 65, which are plastic. I have 2 NOS clips here I will send you. PM me your address. You can have them.
Old 06-15-2022, 08:44 PM
Oh my gosh that would be amazing thank you very much I'm fairly new to the site so it might take me a little while to figure out how to send you a PM
Old 06-15-2022, 10:08 PM
OG68 OG68 is offline
Click on the members name. A drop down menu will enable you to send a private message.
When a message is received from someone, it will show under your name at the upper right hand corner the top of the page. Click on Private message.
2007 Cadillac SRX
Old 06-16-2022, 12:27 PM
webfoot's Avatar
In a pinch I bet a fender washer and a wing nut would work in absence of the clips.
-Jeremy
