Old 04-10-2022, 07:34 PM
6d7gto 6d7gto is offline
Default Can synthetic grease be used on old joints?
Can the grease in the following link be used on original tie rod joints and center link joints? Or should only petroleum based grease be used on the old parts? I heard it is not a good idea to use petroleum based grease on polyurethane bushings but is the converse true?
https://www.ebay.com/itm/171301772401
What grease do you recommend using on older joints?
