Old 05-15-2022, 08:05 PM
wase's Avatar
wase wase is offline
Default Help identifying primer sealer used on my '67 GTO project
Hello guys, I'm posting to ask for help with identifying the material a body shop used on my car so I can get some more for touch up/ spot repairs. This is about my 1967 GTO pictured as my avatar here. I'm not sure what the product was called or the mfg, but the work was originally done around 1999 or 2000. I think the parts store has since stopped selling paint products. Hoping someone will recognize the material and point me in the right direction so I can get a quart for a little touch up. It's a light yellowish color primer or sealer, and I've got a couple of small spots to fix.
Thanks M.D.
Old 06-02-2022, 12:09 PM
wase's Avatar
Hello,
I did some research and checked some local shops. What I've come up with is that
Mar-Hyde Ultimate 2K High Speed Urethane Primer Surfacer Buff 5544
seems to be the material that was used before. Does any one have any tips for spraying it?
Thanks, md
Old 06-04-2022, 03:30 PM
wase's Avatar
Default High Build Buff Color Primer
Mar Hyde 2K
https://www.3m.com/3M/en_US/company-us/help-center/
Sprays using a 1.8 to 2.0 tip and 28 to 35 psi with a hvlp gun
or 35 to 45 psi with a conventional gun
Mix material 4 parts 5544 primer to 1 catalyst # 05557
Old 06-04-2022, 03:58 PM
roger1's Avatar
roger1 roger1 is offline
This is not a good direct-to-metal primer. Was it applied to metal on your car?
It is done in collision type work but avoided on a collector car.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
The Following User Says Thank You to roger1 For This Useful Post:
Old 06-04-2022, 04:37 PM
wase's Avatar
In the few areas that it was, it's lifting.. I'm planning to remove all material in those areas and use rust mort on the bare metal, then cover all bare metal and current bodywork with grey primer, then overall with the 2K. Will this work?
Old 06-04-2022, 04:39 PM
roger1's Avatar
Why not strip the entire car back down to bare metal and start with epoxy primer? That is what I would do.
Old 06-04-2022, 05:58 PM
dhutton dhutton is offline
My advice is to listen to Roger….
Don
Old 06-04-2022, 09:49 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
If it's sat in primer since 99 or 2000 I would definitely strip it back down. Primer is porous and if left for an extended period of time will let moisture through and you most likely will have surface rust underneath it all now. Epoxy primer as a first step stops that from happening if your going to leave the car alone for long periods. Unfortunately anything you apply to the primer on there now will eventually fail.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
The Following 2 Users Say Thank You to n20ta2 For This Useful Post:
Old 06-04-2022, 10:42 PM
ponchonlefty ponchonlefty is offline
will it work?probably . but you have to ask yourself. do i feel lucky?i would listen to the others if i was going for peace of mind. but i am a gambler. it would also depend if it was now or never. in my experience sometimes we take chances and live with the consequence. or do it right do it once.
