Old 06-01-2022, 03:41 PM
gto4evr gto4evr is offline
Originally Posted by 69gtocv View Post
So you're saying the harness in my photo is in the correct position? If that's the case, then you can see how I'd really be stretching it to get the turn signal connector up above the bracket and plugged into the hole. I did find the holes no issue, just doesn't feel right getting it so tight to plug into the hole
I think you need to stop trying to go in front of the bracket and come around the side of the bracket with it and it should reach.
