Old 06-06-2022, 01:48 PM
F ROCK's Avatar
F ROCK F ROCK is offline
Default Cracked A pillars
Both of my A pillars are cracked; and have been for a long time.
I dug into there, to see what is going on.
I was surprised at how much filler was in there.
how are these repaired?
Old 06-07-2022, 12:36 AM
getmygoat's Avatar
Grind out the old filler, reapply. In some cases you can re-weld to build it up and use less filler.
Its a major stress point as the body twists over bumps, or when jacking the car. No way to avoid cracking but the less filler the better.
The Following User Says Thank You to getmygoat For This Useful Post:
