Old 06-11-2022, 08:07 AM
F ROCK's Avatar
F ROCK F ROCK is offline
Default best way to cut hole for hood tach?
Back in the day I used a hole saw. It was not easy cutting the framework.
I'd briefly searched for a fine toothed hole saw; but I'm just wondering if there is a better way?
Old 06-11-2022, 09:42 AM
I do not remember there being any framework. I used a drill bit, a Unibit then a pair of offset snips spiraling outward to the marked circle to reduce distortion.
Old 06-11-2022, 11:05 AM
DOC DOC is offline
Did this a few years ago. Just used a new hole saw for metal. Then put lots of tape to minimize any scratching/wandering. Put a little epoxy primer on with a q tip to prevent rust on the edge. Lots of measuring happened first.
Old 06-11-2022, 11:18 AM
Stuart's Avatar
Stuart Stuart is offline
If you can get a hole punch that's the right dimension, it will make a nice round hole without distortion. You do need to drill a pilot hole for the bolt.
Old 06-11-2022, 02:51 PM
ts3189's Avatar
ts3189 ts3189 is offline
Greenlee punch out tool. Had electrician do mine he thought I was nuts. Took 2 minutes came out perfect.I think it was 3.5 inches.
Old 06-11-2022, 04:27 PM
F ROCK's Avatar
The templates that I have indicate that some bracing will be cut.
I know i cut bracing on the last one. I dont see how you could avoid it?
Does anyone have a photo of the underside of a factory hood tach install for 1971 GTO?
Thanks.
Old 06-11-2022, 07:09 PM
F ROCK's Avatar
As per posts #42 & #43, the hood support channel must be cut for proper placement.
https://forums.maxperformanceinc.com...=451223&page=3
Old 06-12-2022, 08:15 PM
Sounds like you may have to use a cut off wheel to cut through the frame. Then maybe the knock out tool or hole saw.
Old 07-22-2022, 07:48 AM
F ROCK's Avatar
I reached out to Ames for a template which they emailed to me.
Went to lowes, bought a new lennox 3.5" hole saw.
New hole saw had large, strange teeth, said it was for metal.
Easily cut the hole right through sheet metal and frame work. Template was perfect.
Easiest install ever.
Old 07-22-2022, 05:26 PM
70geeteeohh 70geeteeohh is offline
Thanks.
I had to cut a small amount of bracing on my 1970 Gto hood tach install. I had my template 100% in the correct spot. Thought I messed up.
