Old 06-27-2022, 06:38 PM
gtobird's Avatar
gtobird gtobird is offline
Default Use anti-seize or sealer on exhaust pipes and muffler joints?
Folks,
It's been a while since I put an exhaust system on a car. I've never used a sealer or anti-seize on the joints between the exhaust pipes and mufflers, but it makes sense to me. I'm using stainless steel U-Bolt type clamps on 2 1/2" pipes and they are aluminized steel pipes and mufflers, so shouldn't be too hard to crush to get a tight fit. I see that Gardner supplies RTV and recommends using it to get a tight seal. I'm thinking Anti-Seize might be better so I can separate the pipes if I ever need to. But then, which anti-seize would I use? The nickel based Permatex anti-seize is recommended for Stainless tailpipes, but I don't see any of them recommended for aluminized steel like my exhaust pipes and mufflers.
Looking forward to hearing from you all.
Old Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
Old 06-27-2022, 07:03 PM
Walker Acousti/Seal.
Non-hardening, just heat the joint for removal.
Old 06-29-2022, 09:17 AM
gtobird's Avatar
Thanks for the tip. I bought a tube and will give it a try!
Old Joe
