Old 07-02-2022, 04:59 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Default 1979 T/A 403 Olds
Can someone tell me what attaches to these 2 bolts?
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 07-02-2022, 09:53 PM
Trevor78 Trevor78 is offline
On your car, nothing. The 403 (and 350 olds) were built already setup to suit various GM applications straight from the production line. There's various accessory studs from the water pump and the head bolts, to suit different setups and different brackets at the same time.
There's also two on the other side of the water pump top. On some A, B and X models without A/C it is where the alternator bracket runs off. On Firebird models and some others, it supports the bracket for the smog pump. Your alternator bracket uses the same stud but on the RH side at top of pic. I think the Cadillac 350 was one that required those also.
Yours appear to have been swapped, can't tell if they are studs or threaded rod with nuts. I can't see what holds your timing tag on. As long as they work, the tags can crack easily if overtightened which is why they are on a separate stud to that holding the water pump to backing plate.
Old 07-02-2022, 09:57 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
I thought some Oldsmobile engines had a timing pointer that bolted on. However, it may be on the opposite side.
Old 07-02-2022, 10:50 PM
timing pointer is visible on lower stud, plastic with tool holder.
