#41
Its 4.19 (+.040) / 4.5 stroke / 72cc chambers / 40cc dish / gasket = .061 thick 4.25 bore. the pistons will be around .005 in the hole. So we should be real close to 9:1. SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" |
#42
Wow i forgot you have that 4.5 stroke .. So you're 505 at 8.92 to 1 .
I run 9 to 1 with a 3.75 stroke. Before that it was 10.2 to 1 .It worked ok at 20 psi or lower with out tuning issues . My cranking pressure was 190 psi. Now its 170 psi . But when i went above 20 especially over 28 psi i had gasket issues with the 10.2 to 1 . Later i did find out that the ethanol was only at 60% (e85 fuel) so that probably had alot to do with it but either way you look at it your tuning window gets much smaller when the base ratio is higher. The up side of it is you make more power per pound of boost. If you're not planing on going over 15psi i think it would work 9.2 to 1 with a .041 crush . I thought you said you were using a .041 crush. Id use the .041 even though the ratio would be 9.2 to 1. Because the quench will still be in the so called safe zone. With a .060 you will be out of it being you;re .020 under deck . I hope you dont mind me giving my opinion being you didnt ask me. I just wanted to share my personal experience with you ..
My Half AN Injun..... |
#43
All opinions are welcomed... This is what Forums are all about. The parts are already purchased and owned... so anyone with an opinion that changes the build will not be taken with any seriousness. However opinions to help move forward with the parts on hand are always welcomed. I'm fairly sure the 4.5 stroke and 4.19 bore put me just over 496ci... I always wanted to go 500ci or more (symbolic reasons only) however the 496 was set only because the initial build was going to be with my 455 block and it was already @ .040 bore... So I purchased the rotating assembly for that and then got cold feet with running the 455 iron to power levels most sane people recommend against and decided to purchase an MR1 block. 496ci is close enough to 500 though. I do have a set of .041 cometic gaskets however Hurb at Luhn Perf highly recommended that I run their boost specific 5-layer Cometic gaskets (made specifically for Luhn). He said the regular Cometic Gaskets do not go well with boost and their gaskets are specifically designed for boost and will handle the boost better. When I received them they measured a hair over .061... That kind of threw a stick in the spoke. The pistons will be between .005 and .01 in the hole after the block is decked. With the Luhn/Cometic Gaskets It puts it in the 9:1cr ball park. My goal is to run between 15-20lbs but I dont think Ill go over 20lbs... if I ever do I may do a rebuild and and adjust the build for more boost. This is all good dialog. SPEED SAFE, NICK
Thread Tools | |
Display Modes | |
