Carb Adjustment ... No Change in Vacuum Pressure
Cross posting. Post is on FirebirdNation but there is zero activity over there.
So I'm doing my first carb adjustment and I need some help. When adjusting the idle mixture screws, I can't seem to get the vacuum pressure to change. It hovers between 10 and 12 hg. See below. https://1drv.ms/v/s!AkkAtTM66idB6HN8APtdsvBAqkSb I used these procedures https://www.youtube.com/watch?v=UPGLUsW5ZeE https://www.youtube.com/watch?v=dJg8GTlnIH0 Here's a little about my engine. Pontiac 400 block 468 stroker kit. Comp Cam - 20210708_003529588_iOS.heic Edelbrock Heads Torker 2 intake Quick Fuel SS-750 carb - 20210708_004121953_iOS.heic Questions What might cause the vacuum not to change when adjusting the idle mixture screws? When adjusting the idle mixture screws can I just adjust one and then eventually the rest ... or is it best to adjust all when seeking the highest vacuum reading? Thanks in advance! |
I think I'm getting the hang of this. I adjusted each idle mixture screw one turn clockwise which raised the rpm to about 1050 and the vacuum to about 14. I then adjusted the idle down and this is what I ended up with.
https://1drv.ms/v/s!AkkAtTM66idB6HRlh1KGZt1hGclY I think I need to do a little more adjusting of the idle mixture screws to find the spot where the vacuum rises and then falls off. Open to any advice and thoughts. Thanks in advance! |
