66 vs, 67 Z bar
Question... Can an original 67 Z bar be used as a replacement in a 66?
As far as I can tell I would just need to get the rod to Z bar bushing that was used in 67? Thanks in advance for your response. Regards, Joe |
IIRC the '67 has a Zerk whereas the '66 doesn't. Also, the Main/long arm has a slight bend Vs the straight on the '66.
That said I used a '67 in a '66 and don't recall any issues or mods need. I'm sure others will chime in. Cheers
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thank you. Question,,, Do you recall if you used the 66 clutch rod or the 67 rod? I have both. 66 is a repo and 67 is original.
Regards, Joe |
