Where does this go?
Help please... does this peace go between the quadrajet carburetor and my 1977, 400 pontiac engine? Does anyone know if it fits between gaskets or does it sit directly on the engine with a gasket on top of it?
Sits on top of intake. Gasket sits on top of it...
Do you know what the part is? Is there a gasket or Permatex between it and the engine?
And it's got to be there if your EGR is functional
It directs the hot exhaust into the primary bores Keeps exhaust from torching the bottom of the carburetor Shouldn't need any sealer if everything is smooth Clay |
The later EGR intakes have the EGR dump in under the primaries and that plate directs it. Older ones just dumped in the bottom of the plenums..
I’d say it goes on the shelf,along with the heavy intake that has restricted secondaries.
Get an edelbrock, file off name, paint, way better. |
Thank you everyone for helping me. The technical name is a Spread Bore. Respectfully, Paul
The technical name of what?
What it "looks like" it fits would be a description, not a name.
'Exhaust gas distribution plate' is what it is and does. No idea of it's real name Clay |
paperweight.
I'm surprised to see the assertion that these intakes are garbage still persists.
It was either Rocky or Cliff who did an exhaustive comparison of factory intakes for High Performance Pontiac magazine some time back; His comparison showed that the "restrictions" were in a dead spot, and had zero negative attributes compared to other earlier "better" intakes. These OE Pontiac intakes had been proven to all out perform any aftermarket design - with the exception of (I believe it was) the 'performer rpm' - which pretty much matched an OE intake, but had weight savings. but back to the original question, as previously mentioned, those sit on top of the intake below the carb gasket with no sealer required.
The Following User Says Thank You to unruhjonny For This Useful Post: | ||
The ONLY advantage to the Edelbrock Performer over OEM is the weight savings. The lousy fitment alone would make me not want to try to use one. Now the Performer RPM is a different story if you don't have a shaker to contend with.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
/\ now my memory is far from perfect, but I thought the performer actually LOST power when compared to a stock intake on the bottom end;
I had thought that it was the Performer RPM which pretty much matched an OE intake, but had weight savings. ??
https://www.dapa.org/building-a-stro...anifold-tests/ Clay |
https://www.motortrend.com/how-to/hp...take-manifold/
Thread Tools | |
Display Modes | |
