1967 Restoration Parts-The Entire Updated List 9/23/2021
Feel free to inquire with your needs. All parts are NEW unless noted otherwise. Bear in mind these are mostly New REPRODUCTION parts. Very few of these parts are GM NOS. Most were purchased from Ames Performance, OPG. etc. Now offered as a lot for $1500.
Bucket Seat Bracket Set $25 Door Panel Fastener $0.50 Door Panel Fastener Grommet $0.50 Door Top Inside (Beltline) Moldings $35 Rear Quarter Inside (Beltline) Moldings $35 64-67 Door Quarter Watersheds (Paper) $18 Kick Panel Insulation $5 Under Seat Drain Plug $3 Kick Panel Vent Control Cable w/Knob $27 (have 2) Kick Panel Control Cable Clip $1 "Speaker" Bezel for Radio $4 Set of heater control cables $55 Console Courtesy Lamp Lens $7 (no screws) Dome Lamp Reflector $13 Dome Lamp Terminals $3 Visor Bushing kit $10 Parking Lamp Lens Gasket (Pr) $5 Parking Lens Screw & Clip Set $3 Parking Lamp Lens Bezels (Pr) $ 30 Headlight Adjusting Nut & Screw $1 (have 4) 65-67 Headlight Adjusting Spring $1 (have 4) Forward Rocker Trim (cast) $60 for the pair Hood to Cowl Seal $8 Aftermarket hood scoop $65 Exterior Door Handles $70 Door Lock Retainer $1 (have 2) R & L Door Lock Pawl $8 set Right Door Latch $65 Lower door hinges (r+l) $90 for the pair Upper door hinge (just one) $40 Lower Door Hinge Roller Tension repair Kit $13 Door Hinge Pin Repair kit $16 Door Striker $8 (have 2) Window Crank/Door Handle Retainer Clip $0.50 (have 6) Aftermarket window regulator (r) $60 Aftermarket window regulator (l) $60 Vent Window Crank (R&L Pair) $50 Screw-in Replacement Windshield Trim Clip Studs Set $4 Windshield Wiper Arm & Blade Kit $50 Wiper Motor (Cardone 40-120, no core needed) $75 Wiper Motor Transmission Retainer Clip $2 Quarter Window Guide Rollers $12 Gas Door $30 Gas Cap (1964-Vented) $30 Gas Cap (1970 Not Vented) $15 (Not knurled edge type, has 2 tabs) Fuel Tank Straps (aftermarket, slight surface rust) $30 Turn Signal Lever Cam Repair Kit $6 Turn Signal Cancel Springs $2 Blower motor (no AC) $30 Blower motor resistor (no AC) $26 Blower motor switch $55 Aftermarket Front Stereo Speaker w/ Brackets $25 Fuel Pump (w/vent) (Cardone) $42 Fuel Pump to Carb Line (Qjet) $20 Front to Rear Fuel Line (5/16") $50 Front to Rear Fuel Vent Line $50 Fuel Line Clip Set for 5/16" Line w/Vapor Line $10 Fuel Line Clip Set for 3/8" Line w/Vapor Line $10 Quadrajet Choke Pulloff $11 (have 2) Choke Thermostat Coil, Housing Rod $35 Thermostat Housing Bolt/Stud, Washer Nut $4 Thermostat Housing w/Gasket (Cast Iron) $22 Power Steering Pump Mounting Bracket (steel, pump-to-aluminum bracket) $20 Throttle Cable $50 Throttle Return Spring (blue) $6 Intake Manifold Gasket Set (Felpro) $20 65-67 Valley Pan Gasket $6 68-77 Valley Pan Gasket $5 D Port Metal Exhaust Manifold Gasket Set $10 Starter Solenoid Heat Shield $10 Reman Starter Delco 323-256 (1893 732 GM) $90 Reman Starter Solenoid Delco D981 (1114458 GM) $45 Started Mounting Bolt $5 1967-70 Q-jet Throttle Shaft & Bracket $60 Carb to Manifold Vacuum Stud $10 67-70 Q-jet Idle Mixture Screw $6 (have 2) Q-jet Carburetor Float $6 Q-jet Carburetor Mounting Gasket to 1969 $3 Q-jet Carburetor Mounting Gasket 1968-74 $5 PCV Valve $5 Crankcase Molded Vent Hose (90⁰, goes to intake) $7 Carb to Distributor Steel Vac Advance Line (Standard trans) $12 Reproduction Plug Wire Set (dated 4-Q-66) $70 The following Delco parts: Universal Plug Wire Set (12043774) $30 Distributor Cap (12363081) $10 Condensers (12338665) $8 (have 3) Contact Sets (12338660) $17 (have 3) Rotors (12338671) $5 (have 3) Standard Valve Cover Gasket (Rubber) $20 (pair) Outer Dipstick Tube $25 Oil Pan Drain Plug $3 Oil Pan Gasket Set $15 Timing Cover Bolt & Stud Kit $10 Cylinder Head to Block Alignment Pin $4 (have 4) V-8 Head Gasket $15 (have 2) Fuel Pump Eccentric (light surface rust) $35 Timing Cover Gasket Set $22 Engine Freeze Plug Set (Steel) $11 Cylinder Head Freeze Plug Set $6 Harmonic Balancer Bolt $7 Harmonic Balancer Washer $4 Black Nylon Compartment Strap $1.50 (have 5) A/C Vacuum Hose Check Valve $8 Engine side heater (blower) box $30 (surface rust, again not too bad) Heater core (no AC) $80 Heater seal kit $24 2" Fan Spacer (GM) $22 Radiator Cap $13 Upper A Frame Splash Shiels (Pr) $8 Accelerator Pad Pin $2 Accelerator Pad Spring $3 Heater Hose Nipple (Head) $20 Master Cylinder (Std. 4 Wheel Drum Brakes) $50 Clutch Fork boot $8 Clutch Rod Seal $8 Clutch Rod Seal Retainer $12 Shifter Boot for M/T and Console $12 Tailshaft to Hurst 4 Speed Shifter Adapter Plate $25 Shift Cable Floor Pan Grommet $5 Transmission Crossmember Insulator Brackets (pair) $24 Rear Transmission Mount $15 Muncie 4-speed Gasket Set $20 Flywheel cover (std. trans) $30 Clutch Spring Set (2) $16 Clutch fork Ball Stud $12 Clutch Countershaft Bushing $3 Clutch Countershaft Seal $3 Clutch Countershaft Bushing Spacer $5 Clutch Countershaft Spring Clip $1.50 Ball Stud, Clutch Countershaft to Frame $10 Ball Stud, Clutch Countershaft to Engine $13 OEM Style Clutch Fork Pushrod $13 HD Flywheel to Crankshaft Bolt Set $13 Crankshaft Pilot Bushing (Bronze) Parking Brake Ratchet $70 Front Parking Brake Cable (64-67 M/T & Powerglide) $38 Rear Parking Brake Cable (64-77) $38 (have 2) Mickey Mouse Brake Cable Clip $1 (have 4) Front Brake Line Set (Std. Drum Brakes, Steel) $50 Rear Brake Line Set (Steel) $20 Front to Rear Brake Line (Steel) $40 Front Flex Brake Line Clip $1 (have 2) Front Drum Brake Flex Line $17 (have 2) Rear Brake Flex Line $20 Disk Brake Distribution Valve Bracket $15 68-72 Rear Brake Flex Hose Bracket $20 Rear Wheel Bearing $30 (have 2) Rear Wheel Seal $8 (have 2) Front Wheel Bearing Kit (Drum) $70 Axle Flange Gasket $1.50 (have 2) Rear Axle Lubricant 80W-90 GM (23 oz) $12 Front Wheel Cylinder (Left) $20 Front Wheel Cylinder (Right) $20 Rear Wheel Cylinder R/L $15 (have 6) Front Drum Brake Spring Kit (64-72) $10 Rear Drum brake Spring Kit (46-75) $10 Rear Brake Shoe Guide $1 (have 4) Parking Brake Spacer Bar $8 Left Front Brake Adjuster Kit (64-72) $12 Right Front Brake Adjuster Kit (64-72) $12 Left Rear Brake Adjuster Kit (64-72) $12 Right Rear Brake Adjuster Kit (64-72) $12 Upper Ball Joint $22 (have 2) Lower Ball Joint $27 (have 2) Inner Tie Rod $65 (have 2) Outer Tie Rod $45 (have 2) Tie Rod Adjustment Sleeve $10 (have 2) Pitman arm (power steering) $65 Steering Center Shaft $100 Steering Idler Arm $40 Power steering pressure hose $25 Upper Control Arm Bumper $5 (have 2) Lower Control Arm Bumper $5 (have 2) Axle Bumper (pair) $15 Sway Bar Bushing, Stock Bar (pair) $8 Sway Bar Bushing Retainer (pair) $10 Sway Bar Link Kit $12 Front Sway Bar Bushing Set (Stock Bar) $8 Front Sway Bar Bushing Retainer Set $10 Red Rally II Center Lucite $12 64-68 Front Drum Brake Wheel Stud $2 (have 5) 65-77 Rear Wheel Stud $1.50 (have 5) PMD Rally II Center Lucite (Red) $12 Rear Spring Insulators $6 Decal-Turquoise GM Mark Of Excellence (foil) $4 (have 2) Decal-Air Shock Instructions $4 Decal- 421-Tri-Power 425 HP $4 (have 2) Antenna Lead Firewall Grommet $15 Gas Pedal Rod Support (Plastic) $21 Gas Pedal Spring $3 Disc Brake Distribution Valve Bracket $15 Rear Brake Flex Hose Bracket $20 Fan Guard Hardware Kit $4 10-bolt Rear End Cover Gasket $6.50 (have 2) Axle Flange Gasket $1.50 (have 2) Instrument Cluster Lens (Rally w/Tach needle) $30 Instrument Cluster Lens (Rally for Oil/Water Gauges) $12 Chemnick
Just an old goat cruisin' in an old Goat........LIFE IS GOOD!! |
Thank You
A thank you to chemnick!
An honest, straight shooter who went 'above and beyond' to get my purchase to me. Thanks again, Marc |
BUMP...............................
