SOLD Pontiacs The cars in here have already been sold. The topics will be kept for a few months for referance. |
1964 Tempest Drag/Street Car
1964 Pontiac Tempest
535 CI IA2 Block 4.5 Forged Crankshaft Eagle BBC rods Ross pistons Kauffman D port extensively by Dan Barton 380 cfm Victory titanium valves T&D rocker shafts Trend custom pushrods Comp Custom Cam 742/705 271/285 110 Sims Roller Bearing Thrust Plate Moroso vacuum pump Super Victor (ported) Pro Systems Dominator MSD Distributor MSD Digital 8 Box Fluid Damper Recent Freshen Up by Naiser Racing Lincoln Mark VIII Electric Fan TH400 Manual Valve Body Trans Brake Hardened Input shaft 36 Element Sprag with oversized inner race Coan Custom 8” Convertor built for car Custom Driveshaft with 1350 u-joints Ford 9 inch 4.11 Gears Nodular Housing HD Pinion Bearing Support Forged Yoke Mosser 31 Spline Axles and Spool Hotchkins Rear Control Arms with Interconnect Mini Tubbed (will fit 29.5x10.5 slicks) Anti Roll Bar Magna Fuel 625 Fuel Injection Pump and Regulator Factory Tank with Sump Chrome Moly Cage Custom 2’ to 2 1/8” Equal Length Headers 3” Mandrel Bent Exhaust with X Pipe Dynomax Mufflers This car was built for racing but can be street driven. Engine originally dynoed 785 on pump gas, had some head work done at freshen up. Car has gone 9.73 @ 136.9. $29000. Walter (Willie) 512-393-8690 willielansing@gmail.com
1964 Tempest 9.73 @ 136.9, 525, Kaufman D-Ports, Pump Gas 3670 W/Driver. In the 9's on pump gas! |
That's allot of car for the money. I like it
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Really like it! That’s a lot of motor for the street!
Nice street name, are you the developer?
" Darksiders Rule "
Not sure what you mean by "Are you the developer"? If you are asking if I built the car the answer is yes.
I was referring to your street, Willie’s Way.
" Darksiders Rule "
Nope just lucky. Its funny my nickname as a kid was Willie. The address was 98, the year my daughter was born so we had to buy that house.
SOLD
