Old 11-12-2022, 06:52 PM
Welding galvanized steel is difficult due to environmental concerns.
The Following User Says Thank You to poncho-mike For This Useful Post:
Old 11-12-2022, 08:25 PM
Sirrotica's Avatar
And it will make you sick as a dog from doing it. If I weld anything that is galvanized I grind the area where I'm working free of any galvanizing, seen too many friends get sick when using water pipe, and building roll bars.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-13-2022, 10:21 AM
70 bird's Avatar
70 bird 70 bird is offline
These cars were cheap and never designed to last 50 years. How many Toyotas and Datsun's do you see from the early 70's that are rust free??
Old 11-13-2022, 10:40 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Very true. Luckily, anything can be fixed to better-than-new if you have the lettuce.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 11-14-2022, 11:11 PM
4dblnkldude's Avatar
For some odd reason I think the 70-74's rust the worst. That goes for any GM product.
Old 11-14-2022, 11:41 PM
turbo69bird's Avatar
There’s also a product you run through jet ski boat engines and pumps comes under a bunch of differnt names but may be helpful
To some
In Florida.
https://www.saltyhullproducts.com/pr...zing-salt-wash
And this is the corrosion X used in airframes on airplanes most of the time in areas of high salt in the air and even regular areas
https://www.mypilotstore.com/MyPilot...7d971359ef120f
960 HP @ 11 psi, 9.70 at 146.
The Following User Says Thank You to turbo69bird For This Useful Post:
Old 11-15-2022, 05:28 PM
TAKerry TAKerry is offline
For the right price I would buy that car. It would have to be about 30% of value though. I think I would clean, pull the int and replace or repair, do a once over on the motor and drive it like H&&*&&. If it starts rusting in a few years now biggie.
Old 11-15-2022, 09:10 PM
scott70's Avatar
scott70 scott70 is offline
It'll be interesting to see what they ask for the car after they get done with it. Those guys have got some pretty quick FAST cars.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 11-15-2022, 09:34 PM
jhein's Avatar
jhein jhein is offline
It lives! Well sorta. Sounds like they plan on keeping it.
https://youtu.be/pXGNBtMTwCE
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 11-16-2022, 12:03 AM
se428bandit's Avatar
se428bandit se428bandit is offline
That is the Pennington's who own the 2 fastest cars in the FAST race (Corvette, 69 Camaro). They should build that car for the Pure stock class in that race.
The Following User Says Thank You to se428bandit For This Useful Post:
Old 11-16-2022, 01:07 AM
jhein's Avatar
I was wondering if they might do that too.. I'd love to see it!
Old 11-16-2022, 04:08 PM
Transamric's Avatar
Another great quote from that video,...."that interior will clean up real nice!", as they take a pressure washer to it. So many grimace-worthy scenes (and attitudes) there. Sad at so many levels. Sad that the original owners couldn't get to it in time to save it.
BTW, just curious, anyone know roughly how much they paid for this one at auction?
Old 11-16-2022, 04:20 PM
jhein's Avatar
I don't know, but it seems like what most people are saying here is that it would take extraordinary measures to try and save that car, and it still might not be enough. That being the case, why not try to have some fun with it before it succumbs to the forces of nature?
Old 11-16-2022, 04:33 PM
$23,000 + fees
1974 Formula 400 - Ram Air automatic
Old 11-16-2022, 06:10 PM
Formulabruce's Avatar
To Prevent ANY rust, a full spray down with Hold tight 102 must be done. This sprayed in everywhere WILL stop any salts. Will take 5 gallons to do this job. Cavity wax or wool wax after would seal it up nicely.
https://holdtight.com/products/holdtight-102/
Old 11-16-2022, 06:11 PM
Its NOT for sale, they never sell cars that are submerged that deep.
Old 11-16-2022, 06:20 PM
Car rusting in the Garage? I have seen this. One I saw is a '68 get pretty rusty in a buddies garage. Why?
I dug most of the foundation for this garage when we built it. and it was WET ledge mostly. Had to get a small excavator to finish one corner.
After the foundation was poured and walls went up, I leveled and back dragged inside. he also compacted it and had it poured the same summer.
In the summer the floor SWEATS in some places. put hand on it and its wet. Add some heat and that water evaporates and goes Under his car and is trapped, where
those valence Oxygen molecules go to work on the Iron ( FE02)
Since then I look for dark spots and have seen many like this in New England. Guys with lefts have much less problems with this, but its still humid.
  #38
Old 11-16-2022, 06:38 PM
SD455DJ SD455DJ is offline
Yeah, most of the guys that have FAST cars were Pure Stock Drag competitors that began to 'bend' the rules severely and we put an end to that. It is cool what they do and glad they have a venue for those cars where anything goes under the engine paint. We're having troubles with a few 'legal' cars that can run quicker than 11.50 (where the NHRA/IHRA require roll bars) and have to back pedal to not get kicked out. There is/was a '74 TA that was built for FAST (455 d-port and log manifolds) that was running high 10's (John Daigle?).
That said, I'm enjoying watching the car brought back to life and reuse, and I agree, it would be neat to build it for the pure stock drags.
Dennis
  #39
Old 11-16-2022, 07:26 PM
unruhjonny's Avatar
... Sad that the original owners couldn't get to it in time to save it.
The past owner actually chimed in on the comments - it might be buried there - based on the latest video saying that they have been called many nasty things for owning a car lot and buying flood cars...
this is what he said:
My car! It was a nice non SD Trans Am I restored in the 1990's till Ian and the salvage guys got it! Won a few awards at Pontiac shows back in the day. Good to see it getting some attention. After loosing 3 cars and house flooded with salt water I just did not have the time to re restore it and let the insurance company have it. Had a good chat with Terry about the car.
1970 Formula 400
  #40
Old 11-17-2022, 09:02 AM
scott70's Avatar
It's also too bad how they move these cars around with the forks and can cause additional damage. I understand that's the quickest way but it's still cringey to watch it...especially after you've already paid for the car. Smashed exhaust, bent driveshafts, broken valances. 23,000 doesn't sound bad for that car.
