Old 11-22-2022, 07:30 AM
cnc's Avatar
cnc cnc is offline
Default Dash screws
Posted this in the interior tech but no response yet so figured I'd post here
Guys what is the size of the 3 screws that secure the dash to the metal cowl behind the dash bezel think they are 5/16 head ????..the other end are speed nuts that I know .....any help appreciated
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 11-22-2022, 10:36 AM
78w72 78w72 is online now
yes, 5/16 head but not sure of the thread size, they are the same thread size/pitch as the screws used for other items in the dash, like the ones holding the gauges, headlight switch etc. but they might be a little shorter length.
i have probably a hundred of these screws if you need some.
Old 11-22-2022, 01:01 PM
Ramairnacho Ramairnacho is offline
They are actually studs if I remember correctly and go in dash vin metal tray then speed nuts from underside. My dash out but later I can take a pic of one for you
Old 11-22-2022, 01:15 PM
cnc's Avatar
cnc cnc is offline
Speed nuts are on the passs side....I'm sure I can get some here too if, they are the same as the cluster I'll pull some and see how they fit and use those for reference thanks for the offer on the screws too...appreciate the help
Old 11-22-2022, 01:29 PM
be careful when testing other screws, if they are too long they will poke through
or dimple the pad.
Old 11-22-2022, 03:09 PM
Formulabruce's Avatar
IIRC they are #6 sheet metal. And 1 inch long.
Can test this in my 72 a bit later today
Old 11-22-2022, 11:18 PM
cnc's Avatar
cnc cnc is offline
Ok thanks Bruce...
