Old 08-03-2015, 03:38 PM
jjs jjs is offline
Question Power window problem 69 convt fb
My rear passenger side window goes down very slow and needs to be pulled up by hand while operating the switch. The switch and wires get very hot. I removed the switch and have continuity on both up/down wires and power on center wire. Any suggestion would be appreciated. All other windows work fine.
Old 08-03-2015, 08:55 PM
mgoblue mgoblue is offline
Sounds like the window is binding somewhere. I think that would draw more current which would heat up the wires. You may have to remove the interior trim panels to look for the source of the binding. Or maybe the grease just dried up and it needs to be relubricated.
Old 08-04-2015, 09:42 AM
jjs jjs is offline
Talking
I have panels off and sprayed with lithium grease to no effect. Space is limited to do anything. In order to get the motor out you have to drill 3/4 inch holes from a templet in t he manual. I am wondering how they installed the motor initially. I am having a hard time disconnecting the motor to test it. Going to try silicone spray.
Old 08-04-2015, 06:40 PM
tigergto's Avatar
tigergto tigergto is offline
Maybe a bad or corroded connection. I believe the resistance would cause the wires to heat and lack of full current will cause the window to raise slowly.
Old 08-04-2015, 07:49 PM
Bob Dillon's Avatar
Bob Dillon Bob Dillon is offline
Location: Gilroy, California, USA-Garlic Capital of the world!
Lightbulb
The whole panel was pre-assembled and welded in as a unit.
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote."
~Jack Handey, Deep Thoughts
Old 08-04-2015, 08:31 PM
MD79TA MD79TA is offline
Default Replace motot
Replaced al four motor on my 68 convertible and ever had to drill anything
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 08-04-2015, 08:33 PM
Sorry mine was gto. Not firebird
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 08-05-2015, 07:00 PM
jjs jjs is offline
Talking
Checked motor ground, getting 12.4v. greased all moving with pet. jelly. It made some difference but the wires still heat up. It is hard to tell where it is binding or the motor is bad. I guess the next step is to remove the motor.
Old 08-06-2015, 07:45 AM
2002Z4CSS's Avatar
If you do have to replace a window motor there are 3 small dimples on the door sheet metal that line up with the bolts that mount the motors to the regulator. You can take the whole regulator out to unbolt the motor or use a hole saw to make the 3 holes to gain access to the mounting bolts then prop the window up and remove the motor bolts. I have done 100s of these in the years I worked on an Olds dealer.
1971 Pontiac GT-37
Old 08-06-2015, 12:28 PM
jjs jjs is offline
Talking
I only found one dimple centered above two lower bolts. The fisher body on 7-32 shows a picture does not look like what I have.
Thread Tools
Display Modes
