Old 03-14-2021, 12:37 PM
SD421's Avatar
SD421 SD421 is offline
Default Location of Under Seat Metal Wire Cover
Hi,
Can someone tell me or post a pic of where the metal cover that sits under the rear bottom seat go?
It’s been years since I removed it and the screw holes for locating it was covered with “Lizard Skin Sound Deadener “
I have added pics where it seems to fit the best as it lines up with the floor pan stamping (Marked up with yellow)
Thanks,
Don
ID:	562638   Click image for larger version
ID:	562639   Click image for larger version
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 03-14-2021, 08:06 PM
Jeff Hamlin's Avatar
You are correct as it should lay as snug to the pan configuration as possible. I don't think there was an exact spot.
Mine was closer to the center hump but I've seen a few also close to the seat bottom retaining bracket. I would only suggest whichever side you chose,
keep any/all wiring off to the side of the footwell so as not to create any pinching issues. All mine ran along the tunnel.
Old 03-14-2021, 08:11 PM
SD421's Avatar
Thanks Jeff,
That pic and your advice are most appreciated.
-Don
1966 GTO
1966 Tri-Power
1967 670 Heads
