Old 06-24-2022, 05:37 PM
lucky1 lucky1 is offline
Default Sealing material for gap on radiator shroud.
I have an aftermarket plastic “like” fan shroud on my 65 GTO.
There is an about 1 1/2” irregular gap along the top radiator tank.
Is there a foam like material, ideally with adhesive I could use that is heat resistant
And not likely to be sucked down through the gap ?
Thank you.
Old 06-25-2022, 02:42 PM
Yellow Banana's Avatar
Yellow Banana Yellow Banana is offline
I’ve used the black foam pipe insulation to good effect. Just squeeze it into the gap and it will hold and seal your air flow.
The Following User Says Thank You to Yellow Banana For This Useful Post:
Old 06-25-2022, 02:49 PM
OG68 OG68 is offline
Window or door frame insulation that comes in a roll. HD/Lowes. Sticky on one side to stick against the shroud. Different widths and thickness though I don't think there's one for 1 1/2". Pipe insulation may work better
2007 Cadillac SRX
Old 06-26-2022, 10:03 AM
78w72 78w72 is offline
Thank you.
they make the pipe insulation with adhesive on the inside for situations where it needs to stick to the pipe like vertical runs etc.
Old 06-26-2022, 02:38 PM
I've used pipe insulation for the same thing except down each side.
