Old 10-29-2022, 06:51 PM
tabasco813's Avatar
tabasco813 tabasco813 is offline
Default 68 Power Rack and Pinion
Has anyone found a rack and pinion that installs well in the 68 GTO? Talked to Unisteer and they said they do not recommend their 68 A-Body (Chevelle) unit for Pontiacs. Have run into problems with that before. Can't afford a Flaming River. Anyone have a recommendation?
68 LeMans Convertible
Old 10-30-2022, 11:17 AM
JLMounce JLMounce is offline
Rack and pinions in A body's specifically are typically a losing endeavor. The way they mount in the stock frame creates a lot of bump steer.
I would instead spend the money on a good Lee Power Steering or Turn 1 box. You're going to get 90% of the feel without the issues that come along with converting to rack and pinion with the stock frame.
-Jason
1969 Pontiac Firebird
Old 10-30-2022, 12:56 PM
tabasco813's Avatar
Thanks for the advice. By the way, here is a good video of the problems tech support was referring to if anyone is interested:
https://www.youtube.com/watch?v=9ehj6KskcAo
