Disk/ Drum master Cylinder help
I installed the Wilwood 4-piston disk brake kit on the front of my 67. The rear has a drum brake setup. What master cylinder should i be using? The old Strange Engineering catalog used to have a chart in it for with M/C to use- but no more.
Thanks, Steve |
Manual brakes use a 1" bore. Power brakes use a 1 1/8" bore. Use an adjustable prop valve and you should be good to go.
Redline Design |
