Lobes are .398" and .404" which work out to right at .650" net lift with my HS 1.65 rockers. Race weight is 3300. My previous cam was the 254/260 lobes on a 112 LSA. It was just a little too tame for me. I did pick up a couple tenths in the 1/4 when I switched to my 266/272.
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U |
That was the only change I can remember. I was a little surprised at the gain myself. I did the cam swap between the 2016 and 2017 seasons. You can see the ET and MPH difference in my Drag Week averages in my sig.
Do you use a Victor intake?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
I run a 4150 Northwind. At the time I did the cam swap, I was running a 950 cfm 4150 carb on a 2" spacer. I've since switched to a 1050 Dominator on a 2" spacer/adapter.
GT |
I'm still running my 10" PTC that I've had in since the start of the 2016 season. Flashes to 5000 and works really well on the street.
Thread Tools | |
Display Modes | |
