Old 06-08-2019, 09:24 PM
Mike Davis's Avatar
Default Dealer Code/ Zone Help
Looking over a few of the PHS docs I have on a few of my cars, one of my 66's (NSS Car) has a Zone of 18 / 687 Dealer Code,
So Zone 18 is Atlanta, but the dealer 687 is in St Louis MO?
The State CD shows from 21 to 41. Which would be Michigan to Tennessee.
Confused as I have had the car since 1980. It had been sitting in a barn since 1970. I Bought it from the original owner who told me he bought the car new in GA.
Anyone have any thoughts?
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 06-09-2019, 08:15 AM
How do you know the dealer is in St. Louis?
Have a name and address?
Have a pic of the BHC?
(or buildsheet?)
Did he live close to the TN/GA border?
Maybe he thought it was in GA but was just over the line in TN?
Old 06-09-2019, 08:33 AM
Mike Davis's Avatar
Warner could be a likely candidate.
I have some of the dealers formulabruce posted, except Warner, Darr, McMahon.
They were usually (originally?) in alphabetical order.
So it would fall towards the higher numbers.
Vincel is 723 and Thoms is 687, Gene Worn Pontiac is 777, so Warner could fit in there, but would have thought it would be before 777?
I was just going by the info you had posted earlier about Dealer Code 687 being Thoms Pontiac which is in St. Loius
I am not sure where he lived when purchased. When I bought it he lived near Snellville Ga which is about 200 miles from the TN/GA line.
Old 06-09-2019, 10:02 AM
Held for Ransom's Avatar
Zone 12, dealer 687 is going to be different than zone 18, dealer 687 (which would probably start with an R).
So long, farewell.
Old 06-09-2019, 10:22 AM
Mike Davis's Avatar
OK was not aware that there could be same dealer number in different zones. Does anyone know what dealer is 687 in zone 18?
Old 06-09-2019, 12:57 PM
I don't have the dealer name, one reason I was hoping you had a name.
Dealer Codes
With the shipped to state code it could be (and probably is) in TN.
But there are cases of a dealer selling it to another dealer who sold it to a person. In later years the PHS could have 2 examples showing both.
Not sure it worked that way for billing cards though.
As Mike R. said it will probably start with a 'R' in name. No clue where though other than in the zone 18 areas.
Old 06-09-2019, 07:05 PM
Mike Davis's Avatar
John, I do not have the name of the dealer was hoping some here did.
Here is a copy of the billing history.
Old 06-10-2019, 09:17 PM
I wonder if Sparta, TN was part of Zone 18, as there was a Edd Rogers Chevrolet, Pontiac, Buick which started in 1961.
So long, farewell.
Old 06-10-2019, 10:50 PM
Mike Davis's Avatar
Interesting, I forgot they used to be a Pontiac Dealer.
Hope someone has some more info--
Old 06-12-2019, 09:11 PM
Mike Davis's Avatar
Called a guy today that used to work at Edd Rogers dealership in the 70's. He said he did not remember their code and the old man that owned the dealership died a few years ago and his sons run it. It looks like from digging around a little more Edd Rogers was Dealer 544,
So back to looking for dealer 687.
Old 03-01-2021, 11:46 AM
WQ59B WQ59B is offline
In '77, Edd Rogers, 674 West Brockman Way, Sparta, was 18 685.
Old 03-01-2021, 01:55 PM
Mike Davis's Avatar
I still have not been able to find any info on dealer 687 in zone 18 despite years of looking.
Old 03-01-2021, 03:36 PM
Unhappy
Not on my list; have 685, 686, 688 & 689.
Old 03-01-2021, 03:52 PM
Mike Davis's Avatar
Just curious what are the dealer names for 686 and 688?
Here is the sheet for 687
Name:	GTO Build Sheet.jpg
Old 03-01-2021, 10:01 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
FYI, the dealer codes for all the GM dealerships were different, i.e. if the same dealer had Pontiac, Buick, & GMC franchises, they would all three have different dealer codes. And IIRC the areas were different also.
Old 03-02-2021, 05:06 AM
Kenth's Avatar
Kenth Kenth is offline
You may add your info here:
http://www.ultimategto.com/art18.htm
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-22-2021, 12:00 AM
'Ultimate' is dead- no updates I believe since 2009.
Old 04-22-2021, 02:23 AM
Kenth's Avatar
Looks alive to me.
http://ultimategto.com/cgi-bin/ratem...r.cgi?year=All
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 04-22-2021, 07:59 AM
I'd be interested in the names and addresses of those dealers?
Add Dealer Codes
- To add your information so I can add it to the database
Search Dealer Codes - To search for a dealer name or code
Old 08-29-2021, 10:39 PM
Last dealer code update was 04.11.2009.
Don't know why that section has gone dormant if a lot of the rest of the site is relatively active.
