To get back to the original program, I had to repair some accident damage on the lower back quarter of a car, I did use a contour gauge comparing to the other side. But like Musclah said, as long as its close, youre only going to see one side at time. |
A set of torches with the small brazing tip...is the ticket for shrinking metal. A small fine ..pointy flame. The propane flame is way too big ..IMHO.
The Following User Says Thank You to MUSLCAH For This Useful Post: | ||
I wouldn't use a propane torch, that will only cause more problems as it heats to large of an area and takes to long allowing the heat to disperse on the panel distorting it.
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
The Following User Says Thank You to n20ta2 For This Useful Post: | ||
You just gave me a reason to buy and new set of torches. I've lost half the tips for mine and it's pretty much obsolete anyway, can't get parts for it.
I’ve used my stud welder with the shrink tip on those pesky high spots then check with a body file.
1968 LeMans conv. 350 HO - 4 speed triple white (hear it idle here) https://www.youtube.com/watch?v=eVmq...ature=youtu.be 1968 LeMans conv. 350 - 4 speed Solar red/pearl |
The Following User Says Thank You to nytrainer For This Useful Post: | ||
Curious how the shrink tip works, something like a copper tip that heats up a spot using electrical resistance like a spot welder?
I just ordered a Harris #1 torch tip which hopefully fits my 1980's Craftman torch. |
Yes.
bodywork
you can even use a mig welder. heat it hammer it down preferably with dolly and then cool it down.
The Following User Says Thank You to Tim66 For This Useful Post: | ||
So pull the wire out of a MIG welder, use an old tip as the contact?
I assume I'd have to play with the settings on some scrap so I don't blow holes in things, including the welder. |
bodywork
just make believe you're welding a hole 1/2 " after you finish cooling down just grind it and cool with air as you grind
Oh, so you mean actually apply metal with the MIG, I thought it was just using the MIG transformer to provide current to heat a spot of metal.
bodywork
The wire is the heat .
What a mess.....
I'll give the torch method a try first I think.
So far my experience for small imperfections has been ... less is better. Get it close and stop messing with it until a more experience hand can look at it. |
bodywork
I think the torch method works best,I just suggested the mig if you're in a pinch.Good luck with you're build.
I thought you meant using an old tip too. Like dataway, I am curious as to how the shrinking tips work and what they work with. Do they make something like that for a standard wirefeed MIG?
Sent from my moto g stylus (2021) using Tapatalk
Greg Reid Palmetto, Georgia |
This carbon stick set up is the balls. Just remove your tip....wind this rig in...shut the wire speed to off....up the heat a touch....ground said panel...touch the rod to the panel and pull the trigger....flame Less heat to a specific area. |
#38
Don |
#39
My old Solar 165 mig ran it....It’s best to check with your manufacturer to be sure.
#40
Excellent ... I'll get one of those, I have two transformer based Lincoln MIGs that should do the trick.
I'd guess it wouldn't work well with an inverter MIG, they use a computer to sense what's happening at the tip and adjust on the fly ... not sure it would play nice with something like this. |
