OHC-6 TECH Over Head Cam projects, questions and advice.
Old 03-19-2021, 09:52 AM
Default Looks to be a 68 Manual Trans Spring FB on Ohio CL
Seller does not give to much info other than it is a 4bbl OHC-6 with a hood tach
The $5000 asking price seems very optimistic seeing it is a non runner, and as far as it has sunken into the ground I don't hold much hope for floor boards, trunk floor, gas tank, or even sub frames. But you don;t see many complete spring parts cars anymore.
https://youngstown.craigslist.org/pt...292842431.html
Old 03-19-2021, 01:46 PM
Region Warrior's Avatar
Moldy inside. Definitely water intrusion.
Whats up with the rope tied to steering wheel. Help hold door closed?
Old 03-19-2021, 02:25 PM
turbo69bird's Avatar
I’d bet the steering wheel is held for towing purposes.
The car probably needs a lot of metal work but that’s cheap and easy IMO it’s all the little knickknacks that are a PITA if all that’s there and you want a cammer it’s probably a good deal
960 HP @ 11 psi, 9.70 at 146.
