Old 04-25-2021, 05:51 PM
tomc tomc is offline
Default 1966 GTO Factory Tach
I have a 1966 GTO with a stock tach. There are two terminals- with a red insulator and with a white.
Thank I connect the neg coil wire to the red- I get nothing.
When I connect to the white, it goes to 8000 RPM
The dash ground is solid.
What am I doing wrong?
Old 04-26-2021, 11:40 AM
What kind of distributor? I know the HEI ignition will cause problems with an OEM, pre HEI tach.
Old 04-26-2021, 11:46 AM
Factory Distributor with points
Old 04-26-2021, 12:46 PM
Try to contact Peter Serio if he doesn't see this first. He is the gauge guru around here.
