Old 05-02-2021, 08:58 PM
i4abuygto's Avatar
i4abuygto i4abuygto is offline
Default 79 Trans Am - 403 is Holley 750 to much carb.
Hello guys,
I recently purchased my 79 403 Olds with an aftermarket edelbrock performer intake with a 750 Holley double pump carb. It seems to run good with an approx 325 rear end gears and TH400 transmission. I would like to know how to determine if it has too much carburation with the Holley 750.
I recently had the stock heads redone to run on modern fuels and I would like to dial it in to get max performance without a whole lot more investment. The previous owner said the engine was rebuilt with a more aggressive cam then stock. It does seem to run much stronger than stock with a noticeable cam difference however he did not have specific info as to what the cam specs are or what exactly was done internally. And more importantly, exactly what information was used to determine the size of the carburetor that was selected. Holley carb numbers are 4779-7 2989 which, I believe is a Holley 750
Let me know your thoughts.
Old 05-02-2021, 09:41 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Herd tp beat a 750 for all around performance unless you start getting a modified motor.
Skip Fix
Old 05-27-2021, 10:24 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Originally Posted by i4abuygto View Post
Hello guys,
The stock Quadrajet...if set up properly will meet and prolly exceed ALL your performance expectations / requirements....with very little chance of bursting into flames....
The Following 2 Users Say Thank You to Green Hornet For This Useful Post:
Old 05-28-2021, 07:11 AM
77 Canamman's Avatar
Buy Ruggles book. Then set up the 1979 Q-Jet with richer idle and primary metering. It will do everything better than the Holley toilet.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
The Following User Says Thank You to 77 Canamman For This Useful Post:
Old 05-28-2021, 12:11 PM
FWIW....if you have a Trans am.....there is a good chance that your Edeltork intake will change the position of where and how the shaker fits in the hole for it in the hood...
Most Pontiac aftermarket intakes....were not designed with the TA shaker in mind..
Old 05-29-2021, 11:05 AM
i4abuygto's Avatar
Thanks guys for your advice but i dont have access to the original 79 Q-jet as I purchased the car already with the aftermarket intake and Holley 750. I did have to de-rivet the shaker scoop and realign it for the aftermarket intake. I have it centered perfectly so the alignment on the scoop is not an issue.
The car runs strong I just thought I might be over carbed. I set the float levels and Idle mixture to spec on the Holley and adjusted the minor setup variables that Holley recommends without getting into jet changing and all. It doesnt bog or hesitate so it is probably just fine.
Old 05-29-2021, 01:33 PM
Just remember to carry a charged 5lb fire extinguisher with you...and keep 911 at the top of your speed dial list...
The Following User Says Thank You to Green Hornet For This Useful Post:
Old 06-05-2021, 12:44 AM
Aus78Formula Aus78Formula is offline
The beauty of vacuum secondaries, the engine will only use what it can handle.
Old 06-09-2021, 10:40 AM
ta6point6's Avatar
Holley is good carburetor and has been stock on many engines from Ford, GM and Dodge. If your carb does have mechanical secondaries it can tend to drink a little more gas but will run just fine otherwise. The mechanical choke can also be a pain when starting in cold mornings but once again will work fine. Holley does make carbs with electric chokes and vacuum secondaries though. How does car perform when stepping on gas pedal? Does it pick up and scoot or does it bog and fall on it's face. Looking at plugs can tell you a lot about how engine is running rich or lean. Also installing a air fuel gauge is the best tuning tool you could buy in my opinion.
going bandit-Reynolds style
Old 06-13-2021, 08:33 PM
i4abuygto's Avatar
When stomping on it there is no hesitation or bog. I just am not sure that I am getting maximum performance. What is the air fuel gauge that you refer to. I have a fuel pressure gauge in line reading 7 psi to the carb.
Currently there is no choke hooked up and I dont seem to need one as I just need to throttle it up for a little bit and it will stay running.
Carb has mechanical secondaries.
Old 06-13-2021, 11:32 PM
Skip Fix's Avatar
He is talking about a wide band O2 gauge to look at mixture. A bunch of different ones out there.
Skip Fix
Old 06-17-2021, 06:01 PM
i4abuygto's Avatar
Is this an O2 sensor type gauge where the sensor needs to be threaded into the exhaust to check fuel/air.
Of the variety out there, What gauge do you recommend?
Old 06-18-2021, 11:30 AM
ta6point6's Avatar
I use the AEM system comes with everything you need. It comes with a bung that needs to be welded or you could buy one that is clamped in to the exhaust. It cost 160 from Ebay is where I bought mine.
https://www.ebay.com/itm/18476687170...53.m1438.l2649
