Panel bond for full quarter panel
I’m planning to do a full quarter panel and outer wheel house replacement on my ‘75 T/A. I plan to use a MIG welder for the wheel house. I’m wondering if panel bond is an option on the quarter panel instead of welding?
Has no one on here tried this?
I've never used panel bond but wondering how you would do it on a very large panel like that. Do you have to apply the bond around the entire perimeter of the panel and then place it before it starts setting up? Do you have time to make adjustments...or what?
Greg Reid Palmetto, Georgia |
I'm not a body man, but I remember reading that welded metal stays in place where the bonded areas can expand at different rates under the painted surface. Cars that have bonded panel from the factory are designed that way. In a way that its one piece (door panel, hood, roof ..) but on an f-body that quarter panel has that seam going to the roof.
"Honestly the car will only be there for a few weeks, OK maybe a month at the most" Last edited by rustedgoat; 05-10-2021 at 10:15 AM. |
It’s ok for the quarter to wheel house but you should weld the sail panel, rocker, and where it meets the tail panel.
If you read the instructions it will tell you nothing structural should be panel bonded. Don |
That's what I did, I bonded my outer wheel house to the quarter but welded everything else.
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
Ok so no panel bond for structural stuff. But it’s ok on the wheel well lip. Which is good since I’m not good at the inverted welds.
How do I weld the area between the wheel well and door jamb at the bottom of the quarter welded? It where the quarter attaches to the rocker. There doesn’t appear to be any access from the inside. The car is a ‘75 T/A. |
John |
Through the jamb's vent grill opening. |
