Old 05-10-2021, 04:52 PM
ws6speedpaul ws6speedpaul is offline
Default 1969 GTO Rear Axle
When ordering a 400 base engine GTO, what was the standard rear end axle ratio, and was it open or posi?
Old 05-10-2021, 05:08 PM
trishieldchief's Avatar
3.55 open axle no AC.
Rich Johns
www.purestockauto.com
1970 GSX Stage 1 Auto 3.64 # 603 of 678 12.44@109.73 mph 2011 Buick GS Nats Pure Stock, 12.71@110.64 mph PSMCDR 2011
1970 GS Stage 1 Convertible Auto 3:64 12.71@109.15 mph PSMCDR 2009
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
Old 05-10-2021, 05:16 PM
Thanks!
Would this be the same for an AC car, or does that drop to a 3.23?
Old 05-10-2021, 05:27 PM
John Milner's Avatar
John Milner John Milner is offline
I believe it dropped to a 3:23 if you had AC. My base 69 auto 350 horse car with AC came with a 3:23.
Old 05-10-2021, 05:40 PM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
Mine had no air and had 3.23's
The Following User Says Thank You to GTO JONES For This Useful Post:
Old 05-10-2021, 05:49 PM
AG's Avatar
AG AG is offline
I think a 4 speed came with 3.55 and an auto came with 3.23, all other gear ratios were optional unless it was a RA car. Posi was optional on all cars except RA cars.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 05-10-2021, 06:19 PM
PontiacJim1959 PontiacJim1959 is offline
Here is what is found in the AMA Factory Specs for 1969 400CI engine & trans combo's.
Name:	1969 Gearing Options.jpg
ID:	566348   Click image for larger version
Name:	1969 Gearing Notes.jpg
Old 05-10-2021, 07:08 PM
GTO JONES's Avatar
Yeah mine was just a std. 350hp 400 with no air auto 3.23 single track, I still have the original rear end never been apart setting in the garage. same with the motor 197,000 miles on it when I pulled it. I did put 2 timing chains on it.
Old 05-10-2021, 07:13 PM
Thanks everyone for the great feedback, very much appreciated!
Old 05-10-2021, 09:16 PM
Factory documentation states the following standard ratios...
1... 400-350 engine, manual trans and no AC: 3.55, with AC 3.23. Auto trans no AC 3.36, with AC 3.23
2...400-366 engine, all trans with no AC: 3.55, with AC 3.23
3... 400-370 engine, all 3.90 (AC not offered)
4... 400-265 engine, 2.93 with no AC, 2.78 with AC (auto trans only, no manual trans offered)
However, most but not all base engine 350 horse automatic cars without AC I’ve had or parted over the years had 3..55’s. I’ve seen a few with 3.23’s also. I think there was a change to the 3.55’s but I’ve never seen documentation of it. The occasional 3.23 in this application could be either a factory substitution or error or of course a later change out (the 3.23 axle was never officially offered as an optional ratio on the base engine auto no AC powertrain combo).
As an example I recall parting out a rotten but untouched one owner car. It had the buildsheet as well as the original window sticker. It was a 350 horse, auto no AC car but the window sticker showed it was ordered with the optional (standard on an AC car) declutching fan. The car was built with that fan but also the AC sized pulleys and a 3.23 axle (confirmed by the buildsheet), I suspect what happened is during chassis assembly the clutch fan on the engine made the line worker assume it was going on an AC car so he threw in a 3.23 axle.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 05-12-2021, 04:53 AM
I have a 69 a body 3.55 pegleg. What's it worth?
Old 05-12-2021, 08:54 AM
Nodular or not?
I paid $600 for a '69 3.55 Nodular limited slip in decent condition about 2 years ago.
Old 05-13-2021, 10:14 AM
Nodular or not?
Negative on the nodular.
Old 05-13-2021, 10:38 AM
Hmmm.... I wouldn't think it would be worth more than couple of hundred dollars. Just a guess though. If someone nearby needs it for their resto because it's correct and not having to ship it could be worth something to the person in need.
