Old 06-09-2021, 03:10 PM
Poncho60 Poncho60 is offline
Default 1960 gas tank sending unit..repair, replace?
Any recommendations for either repair or replacement gas tank sender for a 1960 Pontiac? I see Ames cuts off at 1961. Thx in advance for any tips/info. RA
Old 06-09-2021, 10:49 PM
fyrffytr1's Avatar
Is this it?
https://autopartsobsolete.com/1959-1...M-5640358.html
Old 06-09-2021, 10:59 PM
Don't think so. Says it's for wagon only. Thx for the effort tho.
Old 06-10-2021, 01:33 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Have you removed and inspected the existing sender? At least a few times I've repaired a sender- float not floating, broken connection at resistor, etc. The last one I repaired, the float arm had (somehow) gotten caught above its up-stop.
Old 06-10-2021, 08:45 AM
jamesq's Avatar
jamesq jamesq is offline
Here is an ebay listing that fits several years. I bought a different listing from the vendor for a 63 wagon and it has worked fine so far. The lister has single and dual lines available.
https://www.ebay.com/itm/40288000844...YAAOSwTjFgGWy~
I hope this helps,
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
Old 06-10-2021, 01:40 PM
Thx much forthe replies.
Old 08-12-2021, 04:57 PM
Burbach 174 Burbach 174 is offline
I just ordered one on Ebay yesterday and should have it tomorrow (using local courier) I think the vendor has more - This has the return line. Stainless. The vendor name on ebay is Vansautollc. Was $39. Someone else also had the non return one too.
