Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
455 Olds carb
I'm looking at a carb for a 455 Olds but I wasn't sure if it was a 750 or 800 cfm. Is there any way to tell by the #'s on the carb?? It it a Rochester carb and has the following #'s on the carb: 7043251 RB 0533. Any ideas??
Also, can someone tell me what cfm means and whats the difference between 750 and 800? |
cfm = Cubic Feet per Minute of air flow at wide open throttle
The easiest way to tell them apart is an 800 cfm Q-jet has larger primary bores, so large in fact that they protrude into the carbs fuel bowl area, so both primary bores have a bump or protrusion in the primary bores if you look down from the top of the carb and open the choke and butterfly valve. here is a link with a picture of both style primary bores http://dyeager535.topcities.com/qjetidentify.html If your carb does not have those bumps it is a 750 cfm carb. FYI I have found very few 800 cfm carbs were made 1970-1974, Pontiac 455 HO's, some Buick and Caddy, I don't know about Olds. From 1975 on very few 750 cfm Carbs were made. They seemed to standerdise on the larger casting size. Hope that helps
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Thats some good info and the pix are very helpful!!
