Am I missing something?
Finished putting the engine back in my 72 gto and bolted the intake down with Felpro gaskets. I noticed this uncovered crossover hole in the head after I bolted it all together (see pic). Is there a special gasket that is supposed to cover this hole? Won't the exhaust come blowing out? Is there a block off plate that goes there?
Thanks in advance for any help. |
Yes,there is a gasket that can cover it.Tom
That stays open.as long as you used 72 gaskets, they go below opening. 72 and newer.
Those are 72 or newer heads and intake, right? Sent from my Moto Z3 Play using Tapatalk
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
So why is that open? Won't the exhaust come blowing out, or is is just for heat?
That is a separate hole not connected to exhaust on 72-newer.
Thanks, I knew someone would have the answer.
And yes, those are the original 7K3 heads and original manifold.
If I remember right, that hole is a non functioning closed off hole. It does nothing. I worried about that when I put mine together too.
What I found to explain the blind hole was that the purpose of this hole is to relieve heat from the cylinder head’s exhaust crossover passage.
Mopar 318CI - "The hole in question is to keep heat from the ex-crossover away from the oil under the valve cover which would quickly carbon-up if the air gap were not there." Ford also did this. Photo is of a Mopar head/intake showing the blind hole/gap. |
