Oil pan gasket preferences
Was wanting to get some input on what you guys prefer for oil pan gasket.
Did I see a one piece out there somewhere? - Edit - I found the one-piece but due to time constraints and $ I want to make a traditional multi-piece gasket set that I already have work. Short of a one piece, what style do you prefer for the part that goes over the rear main cap..ie rear main cap to pan seal. I have a Moroso Pan with a hole in center and 2 slots either side of the center hole for that location. The oil pan gasket set I bought has 2 rubber styles of which only one will fit but it still seems wrong as the rubber gasket has three rubber protrusions that are designed for a hole, not a slot. But you can still pull the 2 outer protrusions into the slots. I have a thick cork gasket for the rear main cap to oil pan location from an old oil pan set I'm thinking of using instead of the rubber. Tell me your preferences and how do you seal it ..ie, what glues or not do you use in the various joints and locations. If I could get away with it I'd use no glue or as little as possible to make teardowns less messy and less work Last edited by RBAILEY; 03-30-2022 at 03:34 PM. |
Absolutely use the cork main cap gaskets. Put a little Ultra black on both sides and you're good. The rubber ones split and leak.
Always used the cork pan gaskets, and they never leaked.
1st time using the 1-piece Butler pan gasket. Kinda nice, but no performance info yet. |
on the one piece, is that the BOP one? that is what i saw on butlers website
do you need silicone on that one? next time i need to do an oil pan gasket i dont want to use that rubber type, i myself had no luck, i should have used cork, but i'll also try to do it with an engine on the stand and not laying on my back under the car |
I hear the cork one is good for no leaks and a tenth..
I like the 1 piece rubber one no leaks yet.
Hot damn!
Here's another 1-piece that is not by BOP but costs twice as much @ $134.00 on Summit.
It is by SCE. Anyone use them? https://www.scegaskets.com/store/pon...number-228090/ https://www.summitracing.com/search/...ord=SCE-228090 |
Factory pan gaskets with cork at the front and rear mains.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
I used the BOP oil pan gasket on our 505 IA2 block and no leaks. I did make a metal spacer for the front section. I also used the right stuff on the back of the main bearing to rubber gasket and at the front spacer. I have used the cork at the back with great success also. I have lots here is you want a piece. Just shipping.
With a four piece set, I like Fel-Pro or Mr. Gasket Ultra Seal. I use the cork rear seal if the cap has a groove. If the cap does not have the groove, I just use Black RTV and at the corners of the timing case to block. The little rear corner reinforcement pieces seem to help.
This is what I use here, stock Felpro for the side rails, cork for the timing cover and custom made thick/wide cork for the rear of the pan. Never had one drop of oil get by this set-up.......
The Following User Says Thank You to Cliff R For This Useful Post: | ||
Thank you everyone on the replies. This is exactly what I was hoping for ie learning from others. I want to know more about the custom cork gasket and if it is running on a rear main cap that has the groove for a much narrower than pictured custom cork gasket. My rear main cap has a groove and I do not recall if all years/modes/etc rear main cap came with the gasket groove or are some just flat with no groove? The width on the custom cork gasket looks good. What type/config of cork stock do you start with and is it spanning a groove on the cap side?
Not all pans & blocks/caps fit perfect so fitment of the cork can be a pita.
Dave Polichena |
The wide custom cork seal replaces the rubber "tit" variety. They are cut wide as shown, no silicone needed on the seal. I just use a small amount where it meets the pan rail gaskets......
