Tiger heads on the street?
Anybody running Tiger heads on a street strip combo?
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017! |
Robin ran them for years on pump gas in the 8's.
Thanks gearbanger, is Robin a member on the site, just want to do some research?
You selling your E-heads ? What you up too ,lol
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
Tigers and a stick shift equals carnage.
Time for a Jerico. |
I have a shop that wants to use my GTO as a testing ground/advertisement, They are building a 505 (4.35 bore 4.25 stroke )with a IA2 block....still trying to figure out the rest of the combo. I am planning on heading south for Drag week as well...so it is going to be quite a year, and I am going to drive it to Drag week, so it has to be durable for the 4500 mile (ish) trip!!!
I will be taking a spare TKO 600 in the trunk, and will be testing the limits of it for sure, both my trany's are cryoed. This is why I have questions about the Tiger heads, One of the shops involved thinks it might be the way to go... Building a custom 6 point rollbar as we speek!
Tiger headed 535 here ran easy 10's with a 3000 converter, 3735 lbs. 3.73 rear. Motor will soon be back out of the car because I want to change a few things. Very streetable as I could not tell they were not the edelbrocks until got on it.
Cool thanks, P4msi1, that is the kind of info I was looking for!
Dang Richard!
Going to Drag Week & your 65 used as a test bed and advertisement? Sounds like a dream come true, how in the heck did you win this lottery Sign me up also. Do you also get a paycheck? The guy they refer to as Robin uses the screen name Mighty T/A but he's using Roland Racing CV-something or other heads now
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
Is this a Tiger headed combo?
Someday I want to do the Drag Week sean.
I'm envios all ready. Have a blast for me please. hhmmmmm someday!!!!!!!!!!!!!!!! GT. |
tiger heads
Fran G. has been running the tigers on his street car for over 4 yrs now. it is a 535 ci 11 to 1 compression 860lift cam and it made 893 hp bad ass.
1966 GTO IAll 535 standar port edelbrocks 10:25 to1 3.89 gears street driven daily best so far 9.99 @ 133 |
Thanks for the info gents. And yes very lucky, having fun is a given!!
Many higher compression race engines have had trouble keeping the head gaskets sealed between the center exhaust ports using Cometic gaskets with the Tiger head. We developed a special alloy insert to improve head gasket life. This upgrade has worked very well for all of the racers that have installed this insert. I would build a longer stroke 535ci engine if I was building a street / strip build with Tiger heads. Calvin Hill Hill Performance 708-250-7420 |
No more tripower?
(http://forums.maxperformanceinc.com/...r.php?u=147905) |
It will be pump gas, so shouldn't be too high of compression (but good to know Calvin).
The tripower might have to get put on the shelf, at least till I build something, maybe a Wenzler tunnel ram with tripower carbs on top. Has to be a some given and take when someone else is paying the tab!! I will check out Mighty T/A posts, Thanks.
You may want to go with HP heads? I think Tigers need RPM to really shine. The power potential will be greatly diminshed by trying to keep them street friendly.
Granted HP's have long valves etc and depending on the ports need a fair bit of lift. But Tiger's want big lift and that isn't street friendly either. One thing cruising to the local burger joint. Quite another doing what you say you will be doing. Just my .02
68 Firebird Are you running with the wind or breaking it? |
Yeah the big lift is definitley a concern, there is no final decision on heads yet...
Calvin,would they hold a gasket better if the bore was kept a touch smaller?Tom
