Old 11-08-2022, 12:29 PM
Default 389 over bore
I can remember back in the 1950's guys over boring some of the old V8's 1/8 inch over. What is the max that a 1964 or 1962 389 could be over bored if it was strictly a street engine?
Old 11-08-2022, 12:50 PM
25stevem's Avatar
25stevem 25stevem is offline
I took a 65 389 out .090" over ( .060" over 400 ) and had no issues on the street, but I think that now looking back I got lucky in terms of core shift which I new nothing about 46 years ago!
I would not go more then .030" to .040" especially if you might be some day handing this motor down to someone who might need/ want to rebuild it again.
I do stuff for reasons.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 11-08-2022, 04:18 PM
Am I wrong, a .060 400 would be almost .120 over 389?
The Following 3 Users Say Thank You to Goatracer1 For This Useful Post:
Old 11-08-2022, 04:22 PM
You’re not wrong.
A 1962 block might be a candidate for that overbore, a 1964 I wouldn’t think so although that was supposedly the last year for thickwall block castings.
Old 11-08-2022, 04:23 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
i thinks its just 59 389 maybe 60 model can go .125 over
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
The Following User Says Thank You to PONTIAC LARRY For This Useful Post:
Old 11-08-2022, 04:35 PM
Definitely. The ‘59 and ‘60 389s had some of the thickest cylinder walls of all the 3” main blocks. Bruce Wilkie and I once had a conversation about over boring a ‘59 389 block .125. Bruce said he had done it but his machinist recommended using Hard Block afterwards.
Dr. Thomas Sowell
Old 11-08-2022, 06:16 PM
25stevem's Avatar
Yup!
I am sure that since it was only making like 370 hp and never topping 5800 that it did not seem to be a issue.
Old 11-09-2022, 10:06 AM
78w72 78w72 is offline
i was concerned about going .060 on a 481988 400 block, spoke to butler about it when ordering the stroker kit & was told that he & beswick used to bore 389 & even some early 400s .90-.100 over with no issues related to the overbore, these were heavily raced engines. he said guys did this all the time before sonic checking was available. its a good idea to check that now when going to a bigger overbore, but guys did this for decades before that service was available.... used stock rods/cranks to pretty high rpms too.
Old 11-09-2022, 12:07 PM
I reason that I ask is because I have a new set of 400cid 0.060 over pistons and both a 1962 389 and a 1964 389. I was wondering if I could use the pistons and one of the blocks. The engine would go into a 1962 Bonneville that will be strictly a cruiser.
Old 11-09-2022, 12:37 PM
racegto65's Avatar
racegto65 racegto65 is offline
I've got a 1965 389 block currently .090 over that has been street driven and bracket raced since it was built in 2007 with no issues. And no I didn't sonic check this one.
Old 11-09-2022, 01:44 PM
geeteeohguy's Avatar
You would be soooo much further ahead of the game by trading/selling the oversized 400 pistons instead of hogging out a decent block to very thin dimensions that will never be usable for an additional rebuild unless it is sleeved.
Seriously. Have a set of dished .020 or .030 over pistons made and run your cruiser for decades to come on pump gas with no worries.
Jeff
Old 11-09-2022, 05:32 PM
I don’t have decades for me to run so it would be the next owner’s problem. I know people don’t like buying second hand engine parts so I figured it would be easier for me to use them.
