Converter slippage
I posted this in the street section by mistake. I recently got to the track after changing from a 10 bolt 3.73 rear to a 9" 4.56 rear and I put a TCI 4500 converter in. I had terrible traction but I still had 1.57-1.58 60'. The ET was a little slow but the MPH was down 3-4 from last year. Once the shift light came on it never went off and I couldn't even feel the shift changes. Is it possible for a converter to slip this much? It was a used converter that I knew nothing about but the part # ID was TCI 4500 stall.
Thanks, Mel |
Mel, what do you shift at? What is your motor combo? It definitely sounds like you are driving through your converter. Was it behind a SBC? If so, then the answer is yes-it is possible to have that much slip. The converter may need to be opened and freshened and set up better for your combo. My.02
fasteddy |
AGAIN:
Calculate the slippage! What RPM were you turning at the line? vs the MPH? vs Gear GEAR X MPH X 336= xxxxxxxx / TIRE HEIGHT= FULLY COUPLED RPM (Zero slippage) Now divide the fully coupled rpm by the observed rpm to find the coupling percentage. Subtract the coupled percentage from 1 to find slippage... Example below plug in your numbers... 4.56 X 115 X 336= 176198.4/ 28"= 6292.8 / 7000= .8989 So 1 - .8989= .1011 or 10.1%I've seen converters adding 30% slippage so anything is possible. JD P.S. Thought for the day "Blowing through a cheap converter"!!! Not cost but quality...
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
The converter is one of TCI's shelf converters. Not cheap though. They sell new for around $575.00. The engine is 467, 4.56 gears, race wt. is around 3400. I may send it out to be set up for my car. Who would you recommend? I can't tell the exact rpm I was turning because I use an adjustable shift light with the factory tach. It is only a 6000 rpm tach and I had my shift light set at 6000. It is just weird how the car would leave that hard and then drop MPH like it did. Thanks for your input.
Does your shift light come on at the end of the track?
What was the MPH and ET incrementals of the run?
68 Firebird Are you running with the wind or breaking it? |
Sounds like a TCI #242300. Put one in my son's car when it ran 12.0.
great 60' but couldn't hear it shift & lost mph. Gave it to a shop to have it "tightened up" no change? Sell it.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Its too loose! Mine is a 4200 conti and u can feel the shift very firmly! Either send it back or sell it
1963 Tempest Convertible Pontiac-Powered Funny Car: 400 block, Littlefield 8-71 blower, Enderle injection, custom blower intake, three-disc glide clutch, three-speed Lenco |
Thanks for the info guys, I think I'll sell it and get a good converter. I have a friend who is going to let me borrow one of his converters for now. The TCI part # 242200. Probably ok for a small block.
I've heard from more than one source that PTC will rework most any brand of torque converter. I've also heard that some of the guys that work @ PTC used to work for TCI back when TCI still was building a fairly decent product,that was back before they got bought out and TCI grew too big for it's own good,and a quality product became less important than overall sales volume. So I'd at least give PTC a call before I got rid of that TCI converter. PTC builds a badass converter,just ask Langer or Pdude. ptcrace.com. FWIW Bret P. |
TCI in fact does make very good converters if you get the right one Their Pro-X line runs very well IMHO... Sounds like you bought a snowmobile clutch though! lol
Contrary to what seems like 'conventional Pontiac wisdom' I hear from time to time, you can make a converter too tight - even for a Pontiac!
The secret to happiness is not getting what you want but rather, wanting what you have. |
FYI - not arguing with you SC. We coincidentally posted over one another - and you were quicker...
And as such,TCI's "rep" among racers has suffered quite a bit in recent times. I kinda think the new TCI Pro-X line of parts & converters are an attempt by TCI to regain some of those long lost "hardcore" race oriented customers. FWIW Bret P. |
All the Pro-X transmissions are assembled by the same guy. Their transmissions are on par with Neals, etc. that are out there. They are working on the converter side but are not on the same level as a Chance or Pro-torque. |
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
