New Gauge install
I bought new Stewart Warner gauges and was wondering if there are any holes already in the firewall that I can use for the temp gauge. I haven't checked it out yet but thought I would ask here first. Thanks
Are these mechanical gauges?
Yes
The only hole possibly big enough would be the speedo cable hole. You might possibly be able to remove the cable put the fitting on your coolant gauge through and then put the speedo cable back through. The tube on the temp gauge is not very thick so you might be able to fit it and the cable.
