Old 03-15-2023, 07:22 PM
swg0204 swg0204 is offline
Default Wanted 70-76 TA Fenders
I am looking for a Pair of Trans Am fender for my 70 TA, any to be had ?
Old 03-15-2023, 08:06 PM
Mr. G Mr. G is offline
Have a passenger side fender removed from a 1979 T/A located in Northern Nevada. Good condition with no filler and no rust.
Old 03-15-2023, 08:29 PM
willing to ship? to So Cal Mr. G?
Old 03-15-2023, 09:26 PM
nas t eh nas t eh is offline
To the OP, you are aware that to look right under the hood you actually need 1970-72 fenders, those are almost impossible to find. You can convert newer fenders by changing out the top inner structure brace from the early fenders and you would also want to add the fender to valence bracket from the early fenders as well.
73 T/A 455, 4speed
Old 03-15-2023, 10:08 PM
I have no donor fenders, also I am aware of the mods that need to be made.
Old 03-16-2023, 09:50 AM
Sure. Not sure if that would be affordable to you these days with shipping rates as they are. Or maybe meet in Bishop?
Old 03-16-2023, 09:58 AM
I do see a pair of fenders in Anaheim on craigslist. Says they are for a 77-81 T/A. Listed in auto parts section under Pontiac on L.A craigslist.
Old 03-16-2023, 07:59 PM
thank you I will look into those
Old 03-17-2023, 10:41 AM
The ad states the fenders are from 77-81, but they look like 79-81 as they have the holes for the later style wheel flares. The ad says passenger fender has some filler in it so if you end up needing a good passenger side fender , let me know.
Old 03-17-2023, 02:13 PM
Many times the average ad lister on Craigs, Fakebook, & even automotive enthusiast bulletin boards has no clue exactly what he/she has. Having driven several hours to look @ parts that were misidentified or misrepresented, it's part of life. Have had several instances recently, of second Gen Camaro doors, being mistaken as both early & late style 2nd Gen Bird doors. It happens.
On second Gen Bird & T/A fenders, the original applications are:
'70-72
'73
'74-75 (some very early '74 models received '73 fenders, I've personally inspected & pulled them)
'76
'77-78
"79-81"..... sometime, during the '78 model , the dual spoiler mtg style began, these were eventually phased out, & the "79-81" spoiler mtg style began to be used.
In the mid '80's, when one went to the dealer & for a 2nd Gen T/A ordered the 1000xxxx part number replacements, one received the dual spoiler mtg style fenders. Have had several nos pairs of that style replacement. Personally, for my own T/A projects, do not like that style. For #1 condition correct early fenders, will continue to change out complete rails & front stamped structure.
Old 03-18-2023, 12:06 PM
The 1970 - 1972 T/A fenders are extremely hard to find. I've only seen one NOS 70-72 T/A fender in my many years of collecting. I picked it up in 1982 for a 1970 Trans Am I owned. It came with an early T/A that was wrecked when almost new, and the owner bought parts to repair.
I've got one NOS 73 T/A fender I acquired in the later 1980s. It has the lower valance brackets. I was extremely lucky to find it.
Every other NOS fender I've seen was later model.
I've seen
Old 04-13-2023, 03:38 PM
grandville455's Avatar
I've got one 73 Fender non ta tho, rust free, the other is a 74 is also non ta ,it doesn't have the valance bracket of course, send me a pm with your phone number and ill send u pics
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 04-13-2023, 03:44 PM
unruhjonny's Avatar
I am writing this to help the OP.
Although it's easy to nit-pick a high dollar car, most of us are content at just having it functionally correct.
(and maybe as aesthetically correct as we can manage)
You can use any 70-81 Trans Am fender for your car they will all bolt on, and are the same shape.
holes for mounting the 70-78 vs 79-81 flares might be the only functional difference - and that's probably easy enough to correct.
My opinion is that the inner fender top difference is really only something to sweat if you aspire to be as correct as humanly possible - most 70-72 cars out there have the 73+ fenders on them.
What you also might want is the brackets to attach the lower valance to the fenders - you don't need it, but if you can get them, and tack them onto the donor fenders it makes everything bolt together all the better.
I am not sure if the valance brackets are reproduced, but they can be removed from any 1970-1973 fender, and as rotted as a fender might be, I have never seen the areas of these brackets being rusty.
Good luck!
1970 Formula 400
