TVS Vacuum Connector
On the TVS, can the vacuum hoses be removed from the rubber connector? I am guessing they can because the recall specifies that the one hose be looped to another port like this.
Is the connector nothing more than a block of rubber that has five female ports on one side and five male ports (or large holes for the hose to be inserted) on the other side? I also noticed there are two styles. Any thought on the reason? |
Ive removed tubing before but it was like it was superglued in or something.
I split the tube and used needlenose pliers to pull it out.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Where can you buy the connector and OEM hoses?
