Old 02-06-2012, 07:51 AM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
Default Back up light switch 4 - speed
I saw this on a 72 Lemans for a back up light. I need to do something like this, I don't much like the rod. Has anyone ever done this before and what parts do you need?
Name:	72 Back up switch.jpg
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 02-06-2012, 10:31 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
This may not be the right place, but I have a new piece that I never used. I bought it for use on my Hurst Comp Plus shifter, I do not believe it is not year specific, $40 shipped (if I can find it) PM me if interested.
Mitch Kunath
Old 02-06-2012, 11:23 AM
The '68 Pontiac A-body & '68 Firebird factory Hurst shifters had a very similar steel piece with the hole it to accept a backup light switch.
In '69, the backup light switch went up on top of the column. I've always thought it odd the manual trans columns in '68 did not have backup light switches, as that provision was used on many '68 big car columns.
Old 02-06-2012, 01:04 PM
I found this. Looks pretty simple.
http://www.summitracing.com/parts/HU...n/?prefilter=1
1964 GTO Auto
Old 02-06-2012, 08:25 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Factory Reverse Lamp Switch 1968
1968 was the last year that Pontiac mounted the switch underneath the car. Starting in '69, it was just simpler to mount it inside; on top of the column, since the steering column now contained a key.
Peter Serio
Owner, Precision Pontiac
The Following User Says Thank You to Peter Serio For This Useful Post:
Old 02-06-2012, 09:41 PM
How was the wire from the 1968 Tempest switch routed?
Old 02-25-2023, 05:18 PM
Default Back up lamp switch wiring=1968 GTO
Across the firewall, there is a "T" shaped black plastic plug-in approx above the bellhousing in front of the firewall, just behind the distributor.
ID:	607894   Click image for larger version
ID:	607895   Click image for larger version
Peter Serio
Old 02-25-2023, 08:59 PM
Vroom_vroom's Avatar
Vroom_vroom Vroom_vroom is offline
If your looking to simplify it hurst makes a back up light switch that bolts onto the shifter itself.
77 T/A- poncho 400| T-10|3.23| I beams|Hyper flat top pistons|Kre heads|Scorpion rockers|Xr276 hydro roller|Rpm intake|Smi qjet|Subframe connectors|Rancho sways|Mcleod super street|hydro clutch|More i cant remember
