Old 03-05-2023, 06:49 PM
70geeteeohh 70geeteeohh is offline
Default How to test 1970 Gto Air recirculation valve.
Does anybody know how to test the valve located behind the passenger side kickpanel.
It has 2 hoses that connect to it.
I am not sure if they work in conjuction with each other of If the both have their own seperate diaphram inside the valve.
Any help is appreciated.
I do NOT own a vacuum gauge. I am looking for a simple way to test it. If possible
Old 04-08-2023, 01:34 PM
Simplest test is to open valve manually then place your finger on the vacuum fitting, release the valve and see if it holds its position, second fitting was to hold the valve in a position between fully open and fully closed, same test for both. They rarely fail unless the car was in hot dry climate like Arizona.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 04-08-2023, 01:43 PM
Thank you so much. I have been patiently waiting and answer. Lol. Have other projects going on so this one was luckily on hold.
Old 04-08-2023, 02:03 PM
Same method for vacuum advance valves on distributors as well as hideaway actuators on 68-69 goats too.
1969 Bonnie Cvt
