Old 03-11-2023, 06:34 PM
jamesq's Avatar
jamesq jamesq is offline
Default BW T-10 info needed
I bought a T10 and shifter at a swap meet today. The owner said it came out of a 62 Impala.
Is this a direct bolt-in for my 63 Safari if my T10 fails?
Info on trans - WG T10 on main case, date 1-2-62 (assume Jan 62?)
tail shaft T10-7d
Shifter - Hurst Comp Plus 149366 - I know this is a later shifter.
Thanks in advance,
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
Old 03-11-2023, 09:20 PM
61-63's Avatar
61-63 61-63 is offline
Yes but you will have to fab up the rear trans mount which is different. I have a Chevy T-10 in my '63 Catalina and had to relocate the trans cross member forward a little and had machine an angled aluminum pad to allow the angled trans installation Pontiacs use. This wasn't a big deal.
Old 03-11-2023, 10:51 PM
jamesq's Avatar
Thanks John,
Forgive my ignorance, but since I have my original trans in the car, can I swap the tail housing onto the chevy unit and reuse the existing mount?
James Q
James Quayhagen
Old 03-12-2023, 11:20 AM
61-63's Avatar
I think the tail housings are the same length and if so yes you could do that.
The Following User Says Thank You to 61-63 For This Useful Post:
