Parting Out 79 400 4 Speed WS6 TA
Before I list on eBay I want to list here first, taking offers as I still do not have an idea of what the going rate is on most of these parts.
Black Exterior, Black Interior PHW Engine Block, Crank Missing, Will take it down to the machine shop to have it cleaned and checked out 6X-4 heads #10003395 Intake Manifold #17059263 Carb #1103315 Distributor 4 speed radiator 400 fan shroud (Very nice) Borg Warner Super T-10 4 Speed Trans 4 Speed Bell Housing 4 Speed Cross Member 4 Speed Drive Shaft 4 Speed Pedal Assembly Disk Brake Rear-End Hurst Shifter w/ Linkage and Shifter knob Steering Box Front Sway Bar Rear Sway Bar Complete Dash, with all guages, insert panel, ash tray, glove box, vents, lower steering column panel (Absolutely complete) Formula Steer Wheel w/Horn Cap Tilt Steering Wheel Standard Vinyl Bucket Seats and Rear Seats All Black Plastic Trim Peices from inside the car are in excellent condition Power Window Motors and Wiring Lock Solenoids and Wiring No Console - But do have a ver nice and complete Console Glove Box 4 Speed Shifter Bezel - A few cigarette burns Power Trunk Release Solenoid with wire and switch Front Bumper Complete with all braces Drivers Side Fender Passenger Side Fender Front Spoiler, Front Wheel Flairs, Rear Wheel Flairs (As Package) - Very Nice Shaker Hood - Very Nice Rear 3pc Spoiler Radiator Support Roof Section - Non T-Top can be removed if anyone interested 4 Speed hump from floorboard can be cut out if interested, let us know how much you want. Driver Side Remote Missor Passenger Door Driver Door Front Engine Bay Wiring Harness - Excellent Condition Dash Wiring Harness Rear Wiring Harness Shaker Hood Scoop, Ring, Original Formed Drain Tube, Air Cleaner, and All Air Ducts - Very Nice Condion and very complete Fender Braces Hood Hinges - Pair Wiper Motor 15 x 8 Snowflakes Many AM/FM radio's for F body's (Inquire) Many other misc parts, please ask |
Is it a nonA/C car? If so how much for the dipstick tube and dipstick?
1971 Formula 400 2000 Formula |
I'm looking for the back shift rod from reverse tab on Trans to swivel and rt side(pass side) kick panel if on good driver condition.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Car has AC, Sorry
PM sent
Photo of shaker also please.
Shaker Scoop - Air Cleaner - Air Ducts
More pictures available on request
Pm sent
Thank you, Hood and wheels also please?
Radio
Looking for a Working AM/FM 8Track
Will have to go to building where these items are stored. Will post soon.
I have had this radio for many years sitting on a shelf. I do not have a way to test it. The flip up door on the 8-Track will need a minor repair job. I took a shot of it needing a little plastic melted over it. This is the optional Clarion unit that was offered. If interested make an offer.
The following items are sold:
Shaker Hood Shaker Scoop - Air Cleaner - All Ducts PWH Engine 6X-4 heads Intake Mainfold Tilt Steering Column Borg Warner Super T-10 Transmission Hurst Shifter Bell Housing Complete Black Dash Pad Thanks Steve S. |
Pm'd you
Steve, backshiftrod and rt. kick panel?
Are you referring to the reverse lockout rod? If so, I think I have it and would need check when I go out to the building where the parts are stored tomorrow. If I have it asking $25 + shipping.
As far as the Passenger kick panel, I do have it, but I was going to post the entire plastic trim as a set first. Or if I have others that want parts from the set I may part it out. Will let you know if you want me to keep you on a list. |
Ok please let me know if you have the rod and about the kick panel
Any pictures of the front sway bar and the pwr trunk release?
Will go dig them out and post soon.
15 x 8 Snowflakes Wheels - Driver Quality $500.00 shipped to lower 48 states
