Butler 461 rotating assembly arrived today. Ross flat top Pistons, Eagle 6.8 rods, Eagle 4.25 crank.
Also got a great deal from PY Member carsmymistress on a Quick Fuel Q850 Carb. Now I need to figure out what heads, cam and converter. Still not sure on Kre 85cc or Eheads 87cc but still thinking of Stump Puller Cam. If I go out of the box, unported heads which one do you guys suggest? |
461 rotating assembly built and waiting
Parts are ordered. Should be here this week. 85cc kre unported dports Jeff Kauffman is grinding me a hyd roller cam similar to stump puller specs Lunati roller lifters 1.65 prw rockers Rpm Intake from member here Got the quickfuel Q850 carb from member here Hedman headers 1 5/8" - 3" collectors into 2.5" pipes already owned 10.2:1 compression on 91 octane Hoping for 500hp / 550tq... Fingers crossed Streetcar only. Idle - 5500 rpm spirited driving only, not a drag car Last edited by Chadmokc; 10-12-2014 at 03:16 PM. |
color me gone |
What brand scraper is that???
my engine was built by Paul Spotts [Spotts Performance] that is his design scraper.
color me gone |
What's your guys opinion on using a crank scraper?
Benefits? For the street? |
my builder likes using [for me any way,and I am sure there will be a boat load of different answers] for me street/strip.......a Canton stock baffled pan,crank scraper and windage tray.
All for HP gain at a given rpm plus keep the oil near the pump pick up and off the crank.
color me gone |
Parts arrived. My wife said I looked like a kid at Christmas.
Does anyone know what Windage tray/screen works with a stock replacement pan and 4.25 crank. Some descriptions say "works with aftermarket pans that are deeper in the front than OE" |
Got a few more questions
Got the engine assembled, painted and parts mocked up and waiting for warmer weather to take it to the dyno. Pulled the 326 out and got frustrated and cut most of the heater and radiator hoses off instead of wrestling them off and reusing them.
1. Does anyone sell a complete heater hose, vacuum and radiator hose set for 66 Lemans with AC and power brakes or do I just need to look up part numbers and order individually? 2. Is there a reason I would keep my stock, great condition starter and not buy the RobbMc starter? Stock works good now on the built 326 with headers but not sure on the new engine. 3. What power will it make? Should be at the engine dyno in less than a month. 461c.i. 4.155ross pistons 4.25eagle crank 6.8eagle rods Zero decked 10.3:1 compression on 91 Octane KRE unported 85cc d ports Hyd Roller Cam similar to Stump Puller 230/236 on 112 Prw 1.65 roller rockers Lunati lifters RPM Intake gasket matched Quickfuel q850 carb RobbMc 550hp fuel pump Accel distributor with super coil Accel wires with ngk FR5 plugs Professional products sfi dampener Hedman 1 3/4" into 3" longtube headers Thanks! Last edited by Chadmokc; 12-30-2014 at 01:27 AM. |
Call your fav parts store on the hoses, the only way I know...get 6' of 5/8 and 3/4 heatrer hose, each, it will be too much, but makes life easier.
Is that a vacuum secondary carb??? Stock starter will be fine. Although the higher compression will be a good test for it!!! Where did you get the Pontiac engine cradle??? Should be close to 500 HP, 600 LB/Ft What ICL did you install cam at???
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... Last edited by 77 TRASHCAN; 12-30-2014 at 03:30 PM. |
you will love the mini starter....I do
color me gone |
Looks like one of these: http://forums.maxperformanceinc.com/...d.php?t=766919
I have 2 of them, they're top-quality.
No it's a mechanical secondary. The engine cradle is from a member here - coupeute - it's the one b-man posted a link to. It's great! I would be all smiles if it makes 500/600 And... I don't have the specs with me now on the cam and I had John at Folks machine install and degree it for me. Hope you had a Merry Christmas! Happy New Year to all! |
Wow!, that little elf is growing!!!
Looking forward to dyno results!!!
Chad:
Following this post. I am about to pull the trigger on the same rotating assembly. I've looked around and most of the assemblies are roughly the same price, but Butlers comes balanced included!! The Eagle crank is it cast steel or nodular? What was the verdict on HP and TQ? I am starting with a 71 400 I am looking to get as close to 500 as well. Thanks, Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
I was at a local car show Saturday when someone told me the Pontiac stroker cranks are no longer being made. I don't believe this. Has anyone heard the same?
Been hearing that for 2-3 years now....Butler, RPM, Galaxy, Ohio Crank, Kauffman, Scat, All Pontiac, and others all have them to sell.
#38
Dittos. Sounds like gibberish to me.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#39
They may have stopped making a few specific cranks but there are many still on the market. For instance, in 2011 I bought a 4" stroke, 3.00" main, Pontiac Rod Journal 2.25" cast crank from PPR (Tomahawk) made by RPM. They no longer make this crank. The cast crank they offer now has the BBC 2.20" rod journals. You can get a forged 4340 crank with Pontiac Journals. But as far as them just completely stopping the manufacture of Pontiac Stroker Cranks, that sounds implausible to me.
Karl |
#40
I remember a couple of years ago Ken Ace Brewer saying they would no longer be available- like doomsday scenario. IIRC he said even the 3.00/4.25 cranks. So much for that...
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
