Old 05-11-2015, 10:04 PM
stroker461's Avatar
stroker461 stroker461 is offline
IMO ya should just call Jeff Kauffman, he will know what cam and stuff works best with his heads ya know, and I dont see any reason ya can't run close to 11:1 on pump gas on a well tuned engine especially with aluminum heads, one thing th KRE heads have a better chamber design than the old E-heads and there are alot of quick cars running the KRE D-ports, 500hp is easily obtainable with those heads, wish ya best of luck.......
  #42
Old 05-11-2015, 10:08 PM
stroker461's Avatar
Sorry didn't pay attention to dates and just went straight to your original post, glad ya got everything sorted out
  #43
Old 05-11-2015, 11:05 PM
Chadmokc's Avatar
Chadmokc Chadmokc is offline
Originally Posted by 1967Tempest View Post
Chad:
Following this post. I am about to pull the trigger on the same rotating assembly. I've looked around and most of the assemblies are roughly the same price, but Butlers comes balanced included!! The Eagle crank is it cast steel or nodular?
What was the verdict on HP and TQ? I am starting with a 71 400 I am looking to get as close to 500 as well.
Thanks,
Dave
The eagle crank is cast. My combo ended up making 468hp 541tq. I am happy with it. She burns the tires as long as I keep it floored. In case I ever want more, I can port the heads and get a bit more out of it but it's a handful now
I ran it at the dragstrip for fun during the Tulsa Pontiac Nationals last week and ran a 12.4@109mph with 245/45/r17 Falken All Season street tires spinning off the line and just easing into it.
  #44
Old 05-12-2015, 08:37 AM
77 TRASHCAN's Avatar
Chad, you did a good job of peddling your car to it's best times @ Tulsa. My other traveling buddies and I are sure there's 11 second times to come w/ sticky tires!!!
The 12.51 run you spun just a tad, the 12.59 run, you spun less, but a tad longer.
Shut it off
Shut it off
