Old 03-15-2024, 09:43 AM
Tomaso Tomaso is offline
Default Rebuild 1968 Pontiac #16 heads??
So I want to rebuild my 68 Pontiac 16x d port heads. 1.77/2.11 valves. Screw in studs. I can’t afford the edelbrock heads right now. The USD is just too high.
I am aiming to do most of the work myself and port them as well myself.
My question is with the Butler head kit, I don’t think I can use the O ring type of seal? Is this correct with the ferrea valves?
It’s a street motor not race. Or am I better to use oe valves with the o rings? Or am I pretty much forced to get them machined for Viton seals?
Mike
Old 03-15-2024, 10:43 AM
steve25 steve25 is offline
Use new valves, and yes they will not have the needed second groove for the factory valve stem O ring if they are SS.
This then means each valve guide too will need to be machined for a positive type seal.
This also means that the factory oil shield must be dispensed with also.
If your not looking to make and cam the motor to make over 400 Hp then I would think twice about porting these heads, especially if you have never done so before and also that you have the funds and a shop that can do a before and after flow test for you.
From flow test I have done on folks home ported heads the owners have picked up some high lift flow, but killed off a good amount of lower lift stock flow.
There’s a cut in stone golden rule to intake and exh flow numbers that goes by a percentage of the valve size used.
It is simply D x.18.
For flat out race heads it’s D x .2.
So for a 2.11” intake valve the math then tells you that up to .380” lift the flow that the cylinder revives is totally controled by the valve job applied and the 1/2” of port shape before the valve seat in the bowl and the 1/2” of chamber shape after the valve seat up to that .380” lift point .
If your running a cam of .500” lift then that’s only 30% more lift then .380”.
If you kill off 10% of the flow you had below .380” lift, yet only pick up 10% more flow up at .500” lift then you are still just about at the brake even point horse power wise because up at .500” lift the cam has less duration then at .380”.
At best with such a condition you have picked up some added port area which will make the HP numbers that the motor does produce not nose over as fast.
On the exh side we see that up to .320” lift the valve job is having the greatest effect.
This being said there is with the right grinding Burr about 10 minutes work of work that can be done to pick up some easy high lift flow.
This type of porting work along with a simple 30 degree back cut on each exh valve will fatten up the flow numbers across the whole lift range.
Exh headers will add 3 to 5% more flow above .300” lift all on there own, and this plus the exh rework above needs to be factored in to the Cam pick as to it being a duel or single pattern Cam.
If you do not know what your doing when porting and you kill off some of that stock air flow up to .380” lift , well what can I say!
The Following 3 Users Say Thank You to steve25 For This Useful Post:
Old 03-15-2024, 01:38 PM
Thanks Steve,
It’s going on a 428. What I was going to spend the money on would be the stroker kit for it. And then hoping to upgrade the heads at a later date…
With that being said using these heads, would I still only be at the 400hp mark?
Mike
Old 03-15-2024, 01:58 PM
If you run a 9.5 comp and a Cam of .550” lift / 225 @ .050”along with 428 cid of displacement, then even with stock heads you should have 380 to 390 hp on tap.
Old 03-15-2024, 02:00 PM
It’s a heavy car. I don’t know if I’m gonna be happy with that. :/
Mike
Old 03-15-2024, 03:11 PM
Happy with that level of HP you mean in your heavy car?
It’s torque that accelerates mass, not HP.
HP is much more of a factor in MPH .
If when you get the funds for aftermarket head and want to maximize torque at any rpm below 5200 then buy a D port aftermarket head and not a round exh port head.
Old 03-15-2024, 03:19 PM
Yes the Dport 72cc e heads were the choice in another thread I had created awhile back, unfortunately, with the usd high I can’t go that route right now.
I have to get the engine built reasonably. I can at least go the stroker route for now and the e-heads later.
I was hoping not to have to do all the work with the heads to go the viton seals though. So I’m at cross road now, on deciding what to do.
Mike
Old 03-15-2024, 04:17 PM
This cutter from Goodson supply and a electric drill will allow you to cut the tops of the guides for the .530” seals you will need to run.
Old 03-15-2024, 04:31 PM
Thank you! I think I will give that a try!! I may have more questions as I go. I’ll post them here. I appreciate the info. Thank you
Mike
Old 03-15-2024, 06:11 PM
Be sure to lube the cutters pilot shaft well when you use it.
Old 03-16-2024, 10:46 AM
Hey Steve,
Also would you recommend using the armasteel crank in my case? Is there a need for a stroker crank? I’m only asking because I have the armasteel crank, and to upgrade its going to cost me 1200-1500cdn
Mike
Old 03-16-2024, 10:56 AM
The stock crank be it Armasteel or NI will be more then fine for your build as long as it passes a mag test.
