Question on frame
I am doing a freshening up of the engine bay on the 69 GTO. I have removed the front clip and engine. On the frame by the motor mounts as well as other areas, I noticed a pinkish colored material underneath the paint. I'm not sure if this is a skim coat of filler or not Would the factory have used filler on the frame prior to painting? I do know the prior owner (original owner) had the engine rebuilt in the 90's as well as the car repainted. These guys repainted the engine the wrong color (64-65 blue) as well as sprayed everything in the engine compartment black. Its a real mess. I'm not so sure these guys would have taken time to smooth out the frame prior to slapping on black paint.
Another question I have is on removal of motor mounts on the frame. Can these be removed? The bolts seem to just spin when trying to remove them. I have looked for access to the backside of bolts so I could put a wrench on a nut, but not having any luck, maybe I am not looking where I need to be looking. Below are some pics. Thanks.
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
Can you tell if it's Filler or Primer?
Filler would not have been used and I'm not even sure they used primers on the Chassis. Likely prior attempt to smooth out normal factory roughness, may want to remove some more to be sure an attempted to hide an issue isn't the case. As far as the Frame Brackets you should be able to get to the nuts through the bottom. Not easily but normally how to get to them.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Every virgin frame I've seen had just that very thin coat of chassis black on it. Those pics are clearly not of factory paint in my opinion.
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
Absolutely, positively not. Even using the word "paint" is a bit optimistic. Chassis black was drizzled in the general vicinity of the frame. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Hasn't changed much... I have a 2016 Yukon XL (Suburban) bought new last spring and already the frame is noticeably rusty after one winter of maybe 5,000 miles.
Thanks Gents! I had a feeling this pinkish material, which I believe to be primer was done by the shop the PO took the car to for engine rebuild and re-paint. I have not seen evidence of this stuff under the car, or anywhere else on the frame. It's only up front forward of the firewall.
Red oxide primer. Autobody 101.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
I usually use a universal socket or socket with a swivel and a extension to get to the frame bracket nuts inside the frame. I think I went through the a-arm holes or a hole in the frame to hold them while turning the bolts. It's not too bad.
Good luck with the freshen up on your 69.
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
