72 cc E-heads on a 467???
Hi guys,
i have a 69 Firebird with an engine that is supposed to be a 467 stroker with edelbrock heads. Upon Closer inspection i found that they are the 72 cc Version. Wouldn´t that put the comperession ratio into crazy territory? What now? |
All depends on the pistons, and the 72 and 87 both have the same casting #.
Depends on the pistons. If they were dished, it could be fine. More info required.
The Following User Says Thank You to Scott65 For This Useful Post: | ||
A compression gauge will be your friend in a situation like this and nail down for you what you have or don't have.
If you show way more then 185 psi then you have the 72 CC heads and near flat top Pistons.
One of those little flexible camera's might be your friend also. If the engine hasn't been run too long and hasn't been super rich, you can look in the cylinder and get a good idea of the piston design on the top. 2-4 eyebrows, D shaped dish, full dish. If it is all carboned up it is very difficult to see in there with a camera. You might have to de-carbonize and then try again. The little cameras are very inexpensive, depending what brand you buy. As little as $25-50. Good luck.
OK, i will check with a compression gauge. What numbers-range would be OK?
Also depends on if the heads had any chamber work done to them. Check the front of the heads for any stamping.
Not to derail the OP’s question, but a what displacement do the 72cc heads become impractical for a pump gas motor?
I guess I’m asking if at some point would the dish size become too big, causing problems. Thanks Murf Sent from my iPhone using Tapatalk Pro |
The Following User Says Thank You to Murf For This Useful Post: | ||
Butler built a 601 cubic inch engine with a 5.000-inch stroke and a 4.375-inch bore using a Indian Adventures "Tall Deck" block. He opted for their heavily modified "Wide Port" version of the Edelbrock heads and I doubt they started out as 87cc castings.
Mild compression ratio of 9.7:1 https://www.flickr.com/photos/119296...n/photostream/ More often than not most of these 'big inch' Pontiac's using Edelbrock heads start out with the #60509 head which is semi-machined and are 72 cc.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 11-13-2020 at 04:18 PM. |
Thanks Steve, I just assumed you could get to a point where the size of the dish would be problematic. Just shows what happens when I assume.
"... get to a point where the size of the dish would be problematic."
That is an area I know little about. But understand the design has a factor. My 505 uses 72cc castings with a JE Custom piston that uses a 27cc inverted dome ( or 26.9?) / depth 0.210 I have 10:1 compression with 79cc chambers. .
Triple Black 1971 GTO |
I'd put a borescope down in there.
Run premium with a little AVGAS and send it.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
"But in reality your compressed volume is 106cc. with 79cc heads, flat top pistons and zero deck you be in Detonate Beach, or Pingsville as you prefer."
Wait what...... plain English please ! My situation.... 4.350 bore 4.250 stroke 79 cc chamber volume .040 gasket thickness Piston to deck .003" ( above deck) 26.9 cc dish About 10:1 compression .
79+27=106cc
My current 455 has 76cc KRE heads, flat tops, 11.3 to 1 compression. It's been on a steady diet of pump gas now over 11 years and is fine. It doesn't like 87 octane that much, on really hot days it has a tendency to "run-on" after shut-down and "bucks" the starter just a tad, so I keep 92-93 octane in it.......Cliff
The Following User Says Thank You to Cliff R For This Useful Post: | ||
72cc E-heads on a 467 with 14cc dish ross pistons. calculates to about 10:7 & runs great on straight 91 no ethanol. will run ok on 87-89 also but as cliff mentioned it can get run on on hot summer days so i just stick with 91 or sometimes 93 with 10% ethanol.
Aluminum heads are more forgiving of higher compression because they wick away heat faster. I've tested a few engines on my test stand and the only two that didn't go nuclear were aluminum headed engines, they never went over 180 degrees...I was amazed.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
