Old 09-06-2021, 12:34 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Getting close. I'm wiring the car now, should be ready to fire up this week.
ID:	572575   Click image for larger version
ID:	572576   Click image for larger version
www.lancablingsolutions.com
Old 09-06-2021, 01:54 PM
Scott65's Avatar
Scott65 Scott65 is offline
Looking good. Keep up the updates.
The Following User Says Thank You to Scott65 For This Useful Post:
Old 09-06-2021, 02:56 PM
R 70 Judge's Avatar
Looking good! Happy to see it all coming together
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 09-06-2021, 03:43 PM
ErikW's Avatar
ErikW ErikW is offline
Please, please, please read and re-read the instructions for Luhn's cam sync. It is an awesome unit but can cause you a lot of grief if setup incorrectly. PM me if you have any issues with it.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
Old 09-06-2021, 03:45 PM
Tom Vaught's Avatar
Boost Engineer
Some very nice fabrication work there.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 09-06-2021, 05:41 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I love it when I see you on youtube representing.
The Following User Says Thank You to ponjohn For This Useful Post:
Old 09-06-2021, 07:28 PM
Mean Green's Avatar
Thanks, will do.
Thanks, I may take you up on that. I haven't even looked at the instructions yet. This is all new to me, I'm just figuring it out as it goes.
[QUOTE=Tom Vaught;6278011]Some very nice fabrication work there.
Thanks.
Thanks, I need to freshen the engine in my red car. But I hope to have this car race ready very soon.
Thanks, some of it should look very familiar to you.
Old 09-19-2021, 05:18 PM
ErikW's Avatar
Default Cam Sync Install
Attached are photos of how the cam sync should be installed. This is what works on our twin turbo car with a Holley Dominator.
So after you set up the crank as described in your PM you sent me. Return to TDC compression stroke and roll the crank back counter clockwise until you reach 195deg BTDC. Then install the cam sync as pictured. Gave you a couple of different angles to see where to set it. Make sure you select "single pulse" and "Digital Falling" in the software. The connector should be pinned, from left to right looking at the sensor as installed, Pin A 12v, Pin B signal, Pin C ipu ground. Let me know if you have any other questions.
ID:	573394   Click image for larger version
ID:	573395   Click image for larger version
ID:	573396   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 09-19-2021, 06:17 PM
Mean Green's Avatar
Awesome, thanks!
Hopefully I'll get the car fired up tomorrow.
Old 09-20-2021, 05:01 PM
Mean Green's Avatar
Does the cam sync body HAVE to be at 9 o'clock. Or is it like a distributor, where you can have #1 wherever you want it?
The reason I ask is because it would work better for me if I could have the sensor plug pointing at 6 o'clock.
Old 09-20-2021, 05:06 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Eric what balancer and "wheel"?
Skip Fix
Old 09-21-2021, 11:35 AM
ErikW's Avatar
That's an ATI balancer and Holley 36-1 wheel.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 09-21-2021, 11:38 AM
ErikW's Avatar
You can point it wherever you want as long as it ends up with the "window" in the position pictured.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 09-21-2021, 07:38 PM
Mean Green's Avatar
Thanks ErikW for all your help!
I set the cam sync exactly like the pic in the instructions and the car shot flames out of the headers. I noticed your pic was 90° off from Luhn's pic. So I rotated the cam sync body 90° and the car fired right up.
Old 09-23-2021, 12:06 PM
JD's Avatar
JD JD is offline
Did you machine the wheel to fit the balancer yourself or have someone else do that?
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
Old 09-23-2021, 12:12 PM
ErikW's Avatar
We machined the back side of the wheel to pilot on the step in the face of the balancer, opened up the center hole to just fit the hub and drilled the three pulley holes after we indexed it. We started with a blank wheel.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 09-23-2021, 12:14 PM
ErikW's Avatar
Glad you got it going!
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #38
Old 09-23-2021, 06:53 PM
ponjohn's Avatar
Will the black car appear on youtube?
  #39
Old 09-23-2021, 07:32 PM
Mean Green's Avatar
Yes Sir.
The Following User Says Thank You to Mean Green For This Useful Post:
  #40
Old 09-26-2021, 01:43 PM
R 70 Judge's Avatar
Update? I’d like to switch to the Holley Dominator system eventually so I’m following your progress
James
1970 Trans Am
