Looking for an original part number tag 9774826 for a Muncie M20 Code 9 trans with 3.90 rear end gears.
Thanks |
I wasn't aware the M20 came with 3.90 rear gears.
It would have made 1st gear almost a granny gear. |
Poncho Mike,
Just to clarify the car has 3.90 rear end. Standard ratio in the M20 Wide ratio. |
you want a tag or a trans? i have a 67 m20 out of a chevelle but it has a pontiac tail housing
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
No, just looking for the tag bolted to the side cover |
In 64 and 65 you could get the M20 -or- M21 ,,,, with 3.90 gears.
My 65 3x2 3.90 car was ordered with M20 (code 9 on Billing History Card) Different speedo gear than regular M20 that was coded "W" on the BHC's from PHS - with 3.23 or 3.36 or 3.55 ratios. |
The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
Thread Tools | |
Display Modes | |
